Zephyrus GX501 BIOS Settings - Switch Optimus / G-Sync ?
Discussion in 'Asus' started by SolarJuice, Apr 20, 2018.
  1. SolarJuice
    SolarJuice Newbie
    Could someone owns Zephyrus Laptop tell me if this machine can switch Optimus / G-Sync via BIOS? Especially the GX501 2018 model.
    I know that it can be switched from ROG Gaming Centre dashboard in Windows 10, but I need to decide whether to buy this laptop or not, depending on if the two features can be switched in the BIOS level. As I am going to install Mac OS X on this laptop, disabling Optimus is nessisary.
    I learne this picture from the asus zephyrus user manual, could some one open the Graphics Configuration tag in the Advance tab of the BIOS Settings and tell me which options it has?
    Many thanks!
  2. Fylen
    Fylen Notebook Enthusiast
    Hi, I will receive mine the 17th so I will be able to answer at that time ^^.
    By the way, I'm doing all my MacOS stuff on a virtual machine (VirtualBox). I didn't know it was possible to install it directly on the hardware. Do you have some good tutorials?
  3. SolarJuice
    SolarJuice Newbie
    I've already got mine and have confirmed that there are no graphic configurations option in the BIOS settings :( . I am hopping that switching to G-Sync in Windows would keep the setting in a hardware level (remains at that status), but I don't count on it.
    Another way of installing Mac OS using virtual machine is by unRaid virtualization (supported by Lime Technology). This way of virtualization has the advantage that I can assign 4 cores of CPU out of 6 (for example), and assign the NVIDIA dedicated GPU directly to virtual machine while the host system only uses integrated Intel GPU, so that the virtual machine won't lose any performance, unlike other virtualization software.
    About installing Mac OS directly on the hardware, I don't have a complete tutorial of doing it. All I can do is to try install it by myself using Clover to boot and solve each problems I would encounter by looking up the Hackintosh forums like "tonymacx86.com". However, I do have another solution to enable NVIDIA GPU under hardware based Mac OS - by using Headless Ghost Emulator Fake Display (buy it from Amazon), so that the OS would recognize another external display and may render things under dedicated GPU. (although additional settings may still needed)
  4. Fylen
    By the way, did you bought the GX501GI (GX501 2018 with 1080) or the GM501? Because I think only the GM501 is able to switch to Optimus / G-Sync...
  5. SolarJuice
    SolarJuice Newbie
    I bought GX501GI. Now I am in UK so I send the amazon parcel to my friend, and I cannot access my new laptop for now. Could you tell me where did you get the info that GX501GI doesn't support Optimus? If you are sure about this, I think Hackintosh this laptop with dedicated GPU would be so easy.
  6. Fylen
    I just read the Global ROG siteweb. In the description, they are saying you can last 5h+ on the GM501 by disabling G-Sync. But no word in the description of the GX501GI :s
  7. SolarJuice
    SolarJuice Newbie
    Yeah, I saw that as well. Guess I made a good choice of buying GX501GI~
  8. Fylen
    And from what you are saying me too ^^ 14 days left to receive mine :p
    Are there accessories in the box? like mouse or RJ45 adaptor?
  9. SolarJuice
    SolarJuice Newbie
    There is a RJ45 Adaptor. You would have a mouse only if you bought the bundle.
    Actually I haven't seen my laptop yet. I bought it on Amazon US while I am in UK, and was sent to my friend. I only saw it by the pictures my friend sent me.
  10. Francesco Campese
    Francesco Campese Newbie
    Hi guys I would like to buy the GX501GI but I'm reading conflicting opinions between the GX and the GM version (with 1070).
    If I understood correctly, the GM version has something called Nvidia Optimus that optimize the performances when you are not playing so the battery lasts really longer than the 1:30h of GX's battery.
    My question is: does only the GM version has this feauture? Is it possible to optimize the battery on the GX?
    Thank you
