ZBook Studio x360 G5 Questions
Discussion in 'HP' started by gamefoo21, Mar 22, 2019.
  1. gamefoo21
    gamefoo21 Notebook Enthusiast
    So I might be ordering a ZBS360G5 soon, but I'm having some difficulty answering some questions.
    First up… What's a reliable way of getting spec sheets for models out of HP? Partsurfer doesn't have all the models and it's often not completely correct it seems.
    Has anyone used the Sure View display? I can't find much about it, and for some reason, HP decided to cripple the specs in the Quick Specs about the SV panel details. I'm kind of torn over the battery life of the FHD SV display and the very pretty but battery hungry AG Dreamcolor.
    Pulled from the ZB 15 G5 Spec sheet:
    Average Operating Power:
    DreamColor 25W (Windows® 10 64-bit)
    Without DreamColor 16.8 W (Windows® 10 64-bit)
    It also has the really sparcely detailed spec sheet on the Sure View display. I was going to use it as the example panel, but it's Anti-Glare, you know like the x360 should be.
    The 15 G5(AG), Studio G5(AG), and the x360(Doesn't say BV or not and no active area measure), all have the same lame spec sheet on the Sure View option. It's so weird that only the 15u G5 has the decent spec layout, but it's active area is a tiny bit different so I'm not sure if I can use those specs.
    Decisions decisions
  2. oliver26n
    oliver26n Notebook Enthusiast
    I have a X360 G5 with the 4K dreamcolor display. It's easily the best display I've ever had in a laptop. On the other hand, I've heard nothing but bad things about the sure view option.
  3. zenbook 70
    zenbook 70 Newbie
    Do you have the glossy of antiglare dreacolor display?
  4. oliver26n
    Pretty sure it's the glossy screen. However, it's not extremely glossy and the screen is so bright that it doesn't even matter. Only screen I can honestly dial down the brightness on, during the day in my office.
  5. Seanrc
    Seanrc Newbie
    I've spent several months with both the DreamColor glossy and anti-glare screens of the ZBS360g5. I'm biased because I don't like glossy screens as they get in the way of my design work. However I would recommend the a anti-glare here as it's actually rated at 600nits whereas the glossy is only rated to 400, so it's brighter! The anti-glare version is also ~.5lbs lighter because they put a glass pane in front of the screen to achieve the gloss. As a bonus they also texture the surface of the anti-glare screen so it has a nicer feel with the stylus.
    When customizing the configuration you must first select the Integrated HD 720p Infrared (IR) DualAryMic Webcam so that the anti-glare DreamColor will appear as an option.
    If your goal is eye candy get the glossy, it's beautiful. But if you want to work on your laptop without lighting restrictions go anti-glare.
  6. T16
    T16 Newbie
    Anyone had any bother with their x360 zbook g5 making very loud and obvious clicking/ticking noises? This cannot be normal surely, it is a seriously annoying distraction.
    You can REALLY hear how loud it is when I zoom in around the 15s mark.
    Video hosted below:-
    https://t16.blob.core.windows.net/public/Videox360.wmv
  7. SuperFlyBoy
    SuperFlyBoy Notebook Consultant
    No - but I have a problem with the microphone recording static for some reason!
    Your link isn't working, btw...
  8. T16
    T16 Newbie
    Just edited, took a space out of the name and re-uploaded.
  9. SuperFlyBoy
    I can barely hear it - even using DellU3417W display speakers - I have much more noise going on...have a dehumidifier working right next to me - and I think my unit's fans and the notebook cooler fans are way louder than that...
  10. T16
    T16 Newbie
    its really loud for me even just using my internal speaker on this Z220 desktop to listen! Must be a frequency response thing.
    Its way louder when the webcam is closer to the keyboard :)
    Like a cricket clicking over and over and over. If I was trying to work in peace it would drive me insane.
