zBook G2 Owners - Alternatives to "Z Turbo Drive"?
Discussion in 'HP Business Class Notebooks' started by timofcourse, Jan 13, 2015.
  1. JacekP
    JacekP Newbie
    I was able to fit 2280 in Zbook 15 G2 but it requires some bravery - I cut off the compartment latch
    and used isolation and duct tape to mount the Samsung pcie m.2 disk. I works perfecty at 820MB/s read speed.
  2. jschoebs
    jschoebs Newbie
    Which specific Samsung M.2 drive did you use?
  3. JacekP
    JacekP Newbie
    SAMSUNG MZHPU256HCGL-000H1 (UXM62H1Q)
  4. JacekP
    JacekP Newbie
    And it was not duct tape but PCV duck tape :)
  5. Willbg22
    Willbg22 Newbie
    Hi all - just took delivery of my SanDisk A110. Will I be able to use the HP recovery disks to install Win7 Pro 64-bit on this drive? My original drive is 1TB HDD. I don't have access to a Win 7 disk or ISO for a clean install :(
  6. Willbg22
    Willbg22 Newbie
    Hi just following up and answering my own question: Yes there is no troubles using the HP recovery disk to get a clean install on the SanDisk A110. Worked a charm first time.
  7. JacekP
    JacekP Newbie
    OK, so not everything is fine with the Samsung disk. If it is plugged-in - I can not boot from USB - has someone a similar problem?
  8. jschoebs
    jschoebs Newbie
    Try disabling secure boot in the bios
    Sent from my SM-N900W8 using Tapatalk
  9. aztec506
    aztec506 Notebook Consultant
    Not much use bothering with them if all you get is 820 mbs is there? Wonder what the Sandisk will do besides fit in the slot.
    I don't understand the previous posters attempts to use a Sata drive in that port. What am I missing? Not trying to be snooty but are there ports on other MBs that will accept either pcie or sata?
    Sent from my iPad using Tapatalk HD
  10. JacekP
    JacekP Newbie
    Yep, 800MB/s is weak - I put the drive in my wife's NUC and NUC gets 1.2GB/s out of it.
    Also there are certaibly bugs in BIOS - After some debugging I discovered that I can only boot Linux and not Windows and only in UEFI mode.
    Does not look like Zbook 15 G2 is ready for m.2 pcie
