zBook G2 Owners - Alternatives to "Z Turbo Drive"?
Discussion in 'HP Business Class Notebooks' started by timofcourse, Jan 13, 2015.
  1. RajoX
    RajoX Newbie
    Hello, I have got the same M2 SSD as you, but I cannot get my 17 G2 to boot from it.
    There is a difference though in what I am doing - I cloned my old 2,5' SSD to M2, and use the old SSD as starting point for the boot process. Let me try to describe my steps, someone might realize where the problem is:
    1. I use Acronis True Image to clone 2.5' SSD to the new M2 SSD.
    2. Reboot with USB drive (I use Macrium PE USB recovery for that), and copy the three files from your zip to EFI partition of old SSD in the right place (EFI\Shell directory)
    3. I run bcdboot command in order to associate Windows folder on the new SSD and EFI partition on the same SSD
    4. Reboot, go to BIOS, edit Customized Boot
    5. Reboot again
    It should work now, but it's not:
    a. I can see from the echo that NVMe drivers are found, the NVMe disk is found, booting starts, but after a while the PC restarts
    I tried also to use another HDD as EFI starting point, made EFI, put EFI\Shel\ files in there, but when attempting customized boot I get a blue windows with error message that winload.efi is missing or corrupt.
    Are there any thought on this situation.
    Many thanks in advance.
  2. RajoX
    RajoX Newbie
    I managed.... So for archival purposes, if someone else gets along cloning a disk to an M.2 PCIe on ZBOOK 15/17 G2:
    1. Clone your old disk to the new M.2 SSD (I used Macrium Reflect)
    2. copy three files mentioned above to EFI partition of the old disk (EFI/Shell directory). You can do it from Command Prompt run as Administrator
    3. DO NOT RUN bcdboot
    4. Reboot, go to BIOS, edit Customized Boot (EFI\Shell\Shell_Full.efi), Save changes
    Voila!
    You can safely swap the steps 1 and 2
    Keep in mind that you should never format your old disk entirely, its EFI partition must be kept safe.
  3. dhv217
    dhv217 Newbie
    I got my Western Digital SanDisk SDAPMUW-512G SN520 512GB {825 MB/s and 807MB/s R/W} working on my HP ZBook 15 G2 - I got Windows 8.1 Pro on the M2 PCI-e drive, the old SATA SSD drive is now partitioned with a 512 EFI drive for the Shell/Driver/Startup script followed by a Linux Mint Partition installation. It took work as I encountered several issues however it worth the speed boost over my old 8 year old Sata SSD drive, boost of 300MB/s in read and almost 600MB/s in write.
    I've been trying for the past week plus to research an EFI scripting solution to easily dual boot between both operating systems using the EFI script above. If I change the second to last line on the script from the existing " EFI\Microsoft\Boot\bootmgfw.efi " to " EFI\Ubuntu\grubx64.efi " the Linux Mint operating system will boot up and of course leaving it pointed at the original entry Windows will boot up. Does anyone have any script examples out there that they could share or link that shows an example where I could add a boot-up option to the script to have it prompt me to choose between the two operating systems?
