Yoga X1 Oled - bright enough for patio? keyboard to stiff?
Discussion in 'Lenovo' started by dman777, Jun 26, 2017.
Tags:
  1. dman777
    dman777 Notebook Consultant
    To anyone that owns the Yoga X1 Oled, please...
    I am thinking about buying a Yoga X1 Oled
    I currently have a Dell E6430 laptop. It is bright enough to see on a covered patio on a sunny day. Would the Lenovo X1 yoga OLED be just as bright?
    I like a normal keyboard with good length of travel distance(like on my Dell E6430). I read where the keys are stiff on this keyboard and travel distance is shallow. Would it be bad enough to make my fingers sore?
  2. ZaZ
    I believe the OLED LCD is 300 nits, which should be usable outdoors as long as you're not in direct sunlight.
    If you want something with more key travel, you should probably get something a bit thicker, perhaps the T470s might be worth a look.
