***Yoga 2 Pro Owners Thread***
Discussion in 'Lenovo' started by JayWalker7, Oct 20, 2013.
  1. duttyend
    duttyend Notebook Enthusiast
    Tonio78370, UncleSpam and Szczepanik like this.
  2. hobbitz
    hobbitz Newbie
    I can't find it on that site. The date of the file on that site is 11/13/2013. Can you give a link ?
  3. Snobol323
    Snobol323 Newbie
    Hi All - First time poster here. I just started having an issue with the cooling fan on my Yoga 2 Pro. It kicked on and ran all night last night. Even after I re-started this morning the fan immediately came back on full tilt and won't shut off. Any ideas how I can fix this?
  4. Tonio78370
    Tonio78370 Notebook Geek
    Same here, none of the European sites show new BIOS... Give a link, give a link :)
  5. Tonio78370
    Did you check in the running applications if something is lurking high CPU usage or did you install something that triggered it ?
    I have my Y2P for almost one year now and don't know what the fan sound like, never heard it. Even when recoding video or vectorizing images it hardly surpasses 60-65° C.
    Good luck
  6. hobbitz
    hobbitz Newbie
    I got it. Just download the file from mobilesupport.lenovo.com. It's version 38. Lenovo updated the file but did not update the date of the file on that page.
    duttyend likes this.
  7. Snobol323
    Snobol323 Newbie
    Hi Tonio - thanks for the reply. Oddly, nothing was running that was consuming a high level of CPU resources, just Outlook and Firefox...maybe 15-25%. I shut down and restart a couple of times this morning with no luck.
    I finally got the fan to shut off by powering down my Y2P and then sitting it on my kitchen counter (granite, so it's cool to the touch) for about a hour. When I powered back up the problem was fixed. Perplexing, but I'm glad it is fixed now.
    As an aside, how do you check the CPU temp?
  8. Tonio78370
    I use CPU Clock gadget with some app (it's marked on the dl page) to integrate CPU temperature
  9. duttyend
    Hi Tonio,
    @hobbitz gave the answer.
    It would have been too easy if Lenovo had put the right date, wouldn't it ? :D
  10. Tonio78370
    Thanks will try tomorrow! BTW any change log available?
