Y50 Replacement Displays Compendium
Discussion in 'Yoga, IdeaPad & Essential' started by Ramzay, Jun 21, 2014.
  1. Midhun Francis
    Midhun Francis Newbie
    I own the lenovo y5070 UHD non - touch screen version . Im an fps gamer ( mainly csgo ) so the 48hz limit of the stock panel is really killing me .
    I was wondering if it is possible to replace that monitor with a FHD monitor with more than 60 hz display for smooth gameplay . i would really like to know if that i possible .
  2. Emil8x
    Emil8x Newbie
    I think you received a TN panel instead of an IPS one. Check the operating mode in the overview section : http://www.panelook.com/B156HW01 V4_AUO_15.6_LCM_overview_686.html. You should return it and ask for a B156HAN01.2 only.
  3. Emil8x
    Emil8x Newbie
    Hey everyone! Thanks to your help I changed my TN screen to an IPS one. It's way better! I got the B156HAN01.1 from laptopscreen.com. It has good colors but it lacks a bit in brightness. So far no problems, aside from 2 stuck pixels and a little bit of light leaking on the bottom left. It's not too noticeable though and I can live with that. Colors seem good. Apparently it covers the full sRGB range according to this test I did: https://www.damiensymonds.net/2010/04/check-your-monitors-gamut.html. I will test with a spectrometer when I get one. Also, my laptop is not a Y50 but a Lenovo W540. So if anyone with a W540 wants to change their screen, here is my tutorial:
    Cheers,
    Emil
  4. orefash
    orefash Newbie
    Hey guys. Are all 30 pin connector edp displays compatible with lenovo y50? or is there anything else to check for? cos the main displays listed in this forum are not available near me. Thanks
  5. ellalan
    ellalan Notebook Deity
    If you could tell us the Country you live in, others might be able to help.
  6. orefash
    orefash Newbie
    Hey Thanks. I'm in India
  7. ellalan
  8. orefash
    orefash Newbie
  9. orefash
    orefash Newbie
    hey did u ever get the screen?
