Y50-70 Cooling mod (it's working dude)
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by Meo, Jun 30, 2016.
  1. Vybramo
    Vybramo Newbie
    Bro try to apply tape there, close to imposible to seal it properly and still u will have gap where u lose pressure to radiator. U can use tap from downside and corners but where is that big hole u need use something like I use.
    As you can read in my post was about 20 celsius. Before i have when browsing about 60+ celsius now 40-45. Ofc I replace thermal paste becaus factory one was like stone and paste is not for cooling but is for filling gaps between heatsing and chip.
    @Victoriu : Im sorry I write I add photos but I dont have time to make cause alot of work. Today or tomorrow I will upload there.
    @Meo: Thermal pad is good to but cost more and alot harder to fill in the gap. Still I think foam is better becaus when u press u make foam smaller and after few sec foam expand and fill gap rly good and i can be 100% shure its dont touch blade or change position.
  2. Support.2@XOTIC PC
    In theory pressure loss should be negligible if the fins are clear of debris, as long as there's nothing to create extra turbulence in the airflow. Clevo just uses a piece of plastic for the same thing. It doesn't seal anything on their models.
  3. Vybramo
    Vybramo Newbie
    Are you serious with ur knowledge of physic? Air always choise way without any resistance. Radiator have resistance and hole? 0 ... For me with replace thermal paste is -20 celsius. When u seal this hole all pressure whichone fan make go trought radiator.
    So photos of my work :
    And dont tell me this is not big HOLE .....SRSLY ? @Tanner@XoticPC something special for you:
    This is Heigh of hole ... OMFG 3,5mm
    This is Radiator height:
    and what abouts fans? Ouu je 10mm
    Still Only one place where you can use tape:
    Final one:
    Maximum what you can put for test on your PC , Furmark with IntelBurnTest.
    So that my results.. On normal use and gaming temps go on cpu about max 70 celsius and Nvidia graphic 60 celsius.
  4. Support.2@XOTIC PC
    Thanks for the additional pics. My comment was based on the original ones looking like the gaps just lead to the inside of the computer, which would build up enough pressure to no longer be the path of least resistance even when considering the radiator. It looks like it might go to other vents from the new images and is a lot bigger than it appeared in the original so I stand corrected.
  5. Victoriu
    Victoriu Newbie
    Thx for additional pics, man. Can you send a picture of this 'special foamgum for high temperatures' ? Or whatever u used to seal this hole
  6. Vybramo
    Vybramo Newbie
    You can see in on first picture where i unseal :)
  7. Rizen
    Rizen Newbie
    What thermal pad thickness should I use for both tasks outlined by Vybramo and Mao? I'm trying to buy some thermal pad online and don't know whether to get the 3mm one or the 4mm one (there is no 3.5mm)
  8. Pablo1607
    Pablo1607 Newbie
    Meo it's a great idea, gonna check it on mine, maybe even I'll add more thermal pad along the heat pipes as long they don't go on vent. Also have some copper shims and if I'll get a good way to fix them to the aluminium case without damaging it I'll add some, have to take the cover first to check is it worth, just changed paste yesterday, used arctic silver. But still waiting for delivery of thermal pads. I know I'll have to repast it again but had gaming night with mate so wanted to something before playing gta online. It's already better after repasting and cleaning whole cooling system. For my surprise there wasn't so much dust inside the fans and radiator after 3 years of having it
  9. DeathBlow
    DeathBlow Newbie
    Forgive me, but what is the specific name of and where did you procure this special foamgum for high temperatures? I'd like to try this out.
    Unfortunately the demonstrative photos included in the OP are no longer hosted, so I can't attempt that mod.
  10. senso
    senso Notebook Evangelist
    Just use some Scotch 33 eletrical tape, or if you want something that is not plastic, aluminium tape used in HVAC ducts, both will do the job without a problem, and wont melt or become loose.
