Xps16 Hard Drive Failure And Dell Design Defect : Excess Heat And Vulnerable Hd Destroy Hard Drive
Discussion in 'Dell XPS and Studio XPS' started by Excelsior, Oct 29, 2009.
  1. Excelsior
    Excelsior Notebook Enthusiast
    Attached are the pics.
    I understand the general proposition that if it will fail it will be more likely the first year then later in its life.
    The point here is to diagnose what may cause a premature failure of the disc.
    Again, I spoke to leading data recovery firm and they confirm these two factors could definitely cause a failure, that is, above and beyond the "normal" failure rate.
  2. Excelsior
    Which part is a stretch of imagination?
    1. That Hard Drives don't like heat?
    2. That the rear lid panel is just 0.40" thick aluminum?
    3. That that 0.04" thick aluminum panel is all that is between the HD and the outside world?
    4. That the lid flexes such that holding the laptop can cause the the lid to make contact and press upon the hard drive itself as shown in the photos?
    5. That windows effort to be Mac like with quick lid on and off doesn't always work and that a laptop that is on with its screen illuminated while closed will generate substantial heat?
    6. That heat causes metal to expand, including metal parts in a hard drive?
    7. That hard drive that expands from heat, even slightly, is more vulnerable to compression forces?
    8. Or is it my imagination that the hard drive failed?
  3. jmorv
    jmorv Notebook Geek
    If it's heat we're talking, check out the Southbridge chip sitting there getting hot as the sun with NO cooling. THAT could contribute to heat for the HD. That is the only design flaw I could see that Dell needs to overcome in terms of keeping this beauty cooler. As far as pressure goes, if you are squeezing the laptop to death that it would bend the bottom metal cover and cause it to touch the hard drive, then you have a VERY firm grip. maybe if you bought some foam weather stripping and stuck it to the bottom metal cover on the inside, you could provide some cushion against the HD but then heat would be a further issue. Wish I had more productive advice, but truth be told, if pressure or physical stability was that big of an issue, Dell wouldn't have left the HD board exposed like that. I know in the HP Pavillion laptops, they have the HD position reversed so the hard metal cover of the HD is facing the bottom.
  4. Mechanized Menace
    Mechanized Menace Lost in the MYST
    I'm so happy I have a SSD I never have to worry about problems like this a(sorry not trying to rub it in) seriously tho, maybe you should get one... JMO heat isn't a problem, silent, and complete metal casing...oh and speed is insane... sucks about your drive tho i dont think the pressure portion of your theory is accurate unless of course your Lou Ferrigno
  5. Ron Williams
    Ron Williams Newbie
    I signed up just to comment on this thread. I purchased my studio XPS in November 2009 after my nearly 4 year old laptop died from hours of daily use (I'm a web developer).
    Today, my laptop turned on twice and said there may be hard drive integrity errors, but instead of actually proceeding to test, windows just booted as usual (or did the test very quickly). Considering the computer (therefor drive also) was new, I figured nothing was awry. Well, the computer crashed, attempted to restart, and bios (the dell screen) never completed loading. Called support, they had me remove and reset the ram among other things. They finally had me unplug the cable connected between the motherboard and hard drive. Bios started, got through its checks, then had an error upon attempting to load an OS. They're chalking it up to the hard drive being dead and have someone coming out on Monday or Tuesday (weird, considering I paid for next day support including weekends).
    I can honestly say this machine gets very hot to the point that it is uncomfortably hot typing at times, even sitting at an angle on a table due to the 9 cell battery. I've already had to have support replace the plastic piece around the fan/head sink since it melted about one month ago.
    As for the problem it has, this is ridiculous and hopefully Monday they will have some recommendation on getting files off since the drive isn't even recognized.
  6. m715
    m715 Notebook Consultant
    Well what temps are to hot for a HD:confused:
    What is a good range to shoot for on a laptop?
    On my 1645 if I play wow my HD is 48-53C, while "trying" to play other games i have seen the HD hit 60C...which seems to hot:eek:
  7. bsknudsen
    bsknudsen Notebook Enthusiast
    Ehm, maybe im just not getting what you are saying. But if the entire chassis of the laptop bends, therefore adding presure to specific areas inside the laptop, maybe you are holding/lifting it wrong? Laptops are pretty heavy and you should never lift them up by the corner using a single hand. Two hands in the middle - always. Im frankly surprised that a hdd would suffer from these pressures though, they are pretty rigid themselves.
    Second, im very surprised to hear that your screen doesn't turn off when you close the lid? Im not yet an owner of a XPS16, but i use a M1530 pretty often, and it surely does turn off the screen, when the lid is closed. If its a problem, just adjust it to put the computer to sleep when you close the lid.
