xps replacement 9570 or stick with 9560
Discussion in 'Dell XPS and Studio XPS' started by trvelbug, Jun 15, 2019.
  1. trvelbug
    trvelbug Notebook Virtuoso
    Dell is willing to replace my existing xps 9560 My question is, should I request for a 9560 instead of the newer 9570?
    I'm actually ok with the performance of the 9560 and don't need more cpu power. Also there seems to be more issues I read about with the 9570.
    So would it be more prudent to just request for a 9560 if given the choice?
  2. JaTXaR
    JaTXaR Notebook Enthusiast
    Dell replaced my 9550 that had a myriad of issues over 3 years, with a 9570. I have only undervolted it and had no problems with it in 6 months. I am still on BIOS 1.5 as there are issues on higher ones so if it aint broke, don't fix it. I have my 1050ti disabled as I use an egpu over TB3 > 4K TV. My personal opinion is you should get the newer version as it has better hardware and would be more saleable.
    trvelbug likes this.
  3. kojack
    kojack Notebook Virtuoso
    I would go with the newer model as well.
