XPS M1710 2nd Hard drive options
Discussion in 'Dell XPS and Studio XPS' started by lancorp, May 30, 2006.
  1. lancorp
    lancorp Notebook Virtuoso
    I'm wanting to start working with Windows Vista Beta 2, and am looking into options to boot to a 2nd hard drive on my XPS M1710.
    At this point, I'm investigating two options:
    1) Having a 2nd hard drive caddy with drive, and would require I remove/replace the hard drive everytime I switch back and forth from XP to Vista (not desireable). Where would I get a drive caddy and does anyone know the part number?
    2) Using D/DOCK with internal media bay loaded with a 2nd hard drive. With this option, I'm not sure I have the option to boot from this drive in the M1710 BIOS. Anyone have any experience with this? Also, I would guess the interface on this media bay isn't very high performance (maybe IDE).
    Any other ideas for booting from a 2nd hard drive? (USB would be too slow).
    Thanks!
  2. mZimm
    mZimm Notebook Evangelist
    I have access to come hard drive caddies. PM me for details.
    It is not possible to boot from an external hard drive; so those are your only options as far as I know.
  3. jcaulley
    jcaulley Notebook Consultant
    Are you saying that it is not possible to boot any OS from an external hard drive or is this a limitation of Windows? I run Linux from an external hard drive and the USB 2.0 interface seems to handle this very well. I didn't really notice any difference in drive access between having it on the USB port and when I had the drive internal to the computer.
  4. mZimm
    Yes, I was referring to Windows. I have booted Linux from an external hard drive as well; but Windows won't do it for some reason. Windows doesn't have a problem booting from the hard drive caddy though since it's connected to the IDE channel.
  5. drumfu
    drumfu super modfu
    is there a reason you don't just dual boot your machine? that's what i did with the earlier release of the vista beta
  6. jcaulley
    lancorp, not sure if you are willing to spend a little money to do this, but if you are this is an Xpress card that will give you an external SATA capability. Couple that with an external SATA enclosure (~$25) and you can have an external harddrive that runs at internal HDD speeds and will allow you to install windows.
