XPS 15 9570 will have the same thermal issues as its predecessors
Discussion in 'Dell XPS and Studio XPS' started by Eason, May 12, 2018.
  1. _sem_
    _sem_ Notebook Deity
  2. woohoo7676
    woohoo7676 Notebook Enthusiast
    Just got my 9570 - it looks like SpeedShift is now supported, there is a section in the BIOS with "Enable Intel Speed Shift Technology". Also in hwInfo64, SST is green.
    improwise and pressing like this.
  3. pressing
    pressing Notebook Deity
    Great!
    What BIOS are you running on the 9570?
    I think you set EPP in Windows>Control Panel> Power options. That EPP dropdown might not be available; if so you can enable it manually.
    EPP=0 for max performance
    EPP= 100% (or maybe 255) for max battery life
    EPP = 50% (or maybe 128) for typical use per Intel
    EPP ~33% (or maybe 70) for a balance which allows you to hit max turbo clocks when needed. You will need to find this point yourself
  4. GoNz0
    GoNz0 Notebook Virtuoso
    pressing likes this.
  5. woohoo7676
    Looks like the bios is 1.0.5 (4/23/2018)
