XPS 15 9550 temperature observations (undervolt + repaste)
Discussion in 'Dell XPS and Studio XPS' started by custom90gt, Dec 28, 2015.
  1. GoNz0
    GoNz0 Notebook Prophet
    Progress, The DIMM sensor is not the DIMM sensor at all. I think it shows correct in the BIOS as it seems low but Aida64 reports the sensor on the edge of the board shown here
    HWiNFo64 shows the right sensor.
    Amazing what you can find with a q-tip with a drop of liquid air as it dropped the sensor from 55 degrees to 10 degrees in an instant!
  2. GoNz0
    And I am removing the thermal pads off the back of the heatsink as the whole laptop is getting warm, it isn't worth it.
    pressing likes this.
  3. Bommel87
    Bommel87 Notebook Consultant
    That is a very nice find. Thank you! So it seems that this sensor corresponds to the voltage regulation for the CPU/GPU. Makes sense, these things are usually cooled on GPUs.
  4. Eason
    Eason Notebook Virtuoso
    So, what does this censor do, again? Would cleaning it with alcohol make a difference, or it requires some special applicant?
  5. Bommel87
    The voltage regulators around the sensor supply the CPU/GPU with power. In that transformation process, they produce heat. That sensor simply measures the temperature in that region. Cleaning it won't help, but you can put passive coolers on the regulators.
    Gonzo used liquid N2 to locate the sensor on the board. He observed the temperature in bios while cooling it and then concluded it must be that device on the board.
    Kikuri and Eason like this.
  6. Eason
    Ok. Was curious if that was causing my firmware-level CPU throttling after a few minutes of gaming. It isn't PROCHOT, temps are fine, and it isn't TDP-- it's something in the firmware. It can be overridden with TS, but I'd rather not have to.
  7. GoNz0
    I use AIDA64 and it bugged the hell out of me as I knew DDR4 wouldn't get that hot. I didn't test it in the BIOS as that seems to read correct, I knew that sensor was 10 degrees above everything else at the time.
    Maybe the AIDA64 dev can get the right sensors sorted out, I am waiting for his reply after providing sensor dumps. I got the 9530 working via dumps last year so fingers crossed.
    Kikuri, Eason and Bommel87 like this.
  8. Bommel87
    They should pay you for that. Nice work!
    By the way: You said that the BIOS reading is correct (for DIMM I assume)? For me, that is already enough to know.
  9. zuffy
    zuffy Notebook Guru
    I repasted my XPS L502x and 9550 with MX-4. Got a little better result than Arctic Silver 5.
    Kikuri likes this.
  10. GoNz0
    Aida64 has been updated, the latest BETA now has corrected readouts, temp4 is not the DIMM from what I can gather via HWiNFO64
