XPS 14 with LG screen dims on its own randomly
Discussion in 'Dell XPS and Studio XPS' started by noji, Jun 26, 2011.
  1. noji
    noji Notebook Enthusiast
    I swapped my XPS14 screen for the LG 1600x900 screen. I've noticed that randomly the screen gets dimmer for a few seconds and then brightens back up. I cannot correlate it with anything, this does not seem to be a power setting issue. I remember this being mentioned before by people, has anyone come up with a fix?
  2. machiz7888
    machiz7888 Notebook Consultant
    its probably a battery life setting, its either in the intel settings or windows power settings. It changes the screen contrast to save battery life or something along those lines.
  3. NoAirBanding
    NoAirBanding Notebook Geek
    Did the power cord get bumped?
  4. SimoxTav
    SimoxTav Notebook Evangelist
    Same here with the XPS 15, I noticed it on white backgrounds mostly... I have an AUO screen, so it seems it's a matter of IGP instead of a generic issue or a screen one...
  5. Tsunade_Hime
    Do you have Optimus? There seems to be an issue with Optimus and random dimming. Does it do it on an external monitor? Did you check if you are on battery/AC power?
  6. noji
    I do have optimus, and this is not a power setting dimming. It just gradually dims and loses contrast unlike a power screen dimming. It then comes back after a few seconds. Can the person who mentioned Optimus and random dimming tell me more?
  7. namaiki
    namaiki "basically rocks" Super Moderator
    There is a certain Intel DPST (Display Power Saving Technology) option under "Power settings" in the Intel GMA control panel that you could try disable/check.
  8. hockeymass
    hockeymass that one guy
    This might be unrelated since you say it doesn't correlate with anything, but Dell has this "Intelligent Display" feature which dims the screen when it is predominantly darker colors and brightens it when lighter colors are on the screen. Nice in theory, kind of annoying in practice.
  9. SimoxTav
    Probably this one..
  10. NoSlow5oh
    NoSlow5oh Notebook Evangelist
    Are you using Fast Access Facial Recognition? There is a setting in there that can dim the backlight if the camera doesn't detect motion for an extended amount of time. It will then resume once it detects movement. Probably not that but it's happened on mine and I disabled it.
