XPS 13 or 15?
Discussion in 'What Notebook Should I Buy?' started by Omer D, Jan 1, 2017.
  1. Omer D
    Omer D Notebook Enthusiast
    I have a Thinkpad W500. It's not as fast as I'd like but my main concern is that it is not portable. It's really heavy (and the battery is terrible). Also, I think the graphics on it, though dedicated, are not very good for making videos and I'd like to do that as well.
    My main concern is portability. A good keyboard is important as well.
    I'm thinking about the XPS 13, but it doesn't have dedicated graphics so I'm not sure how good it would handle video editing. If I could get a 15 inch laptop that is also very portable I would be happy. Would love to hear from you. I thought about the XPS 15 (though over my budget), but it seems to be not very different from the w500 in terms of weight.
    Refurbished and even used from ebay is definitely an option... Thank you for your help.
    General Questions
    1) What is your budget?
    900$
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15"
    ebay?
    a. Like:
    Dell, Lenovo, Asus
    b. Dislike:
    Apple
    Yes
    Programming, some video editing, some music editing, internet/office.
    YES, I want to carry it in my bag pretty much everywhere (have a W500 Thinkpad can't do that now).
    No, but graphics may be important (for video software).
    As many as I can get, but 5+ would be ok for now..
    No need to see.
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Win 10 (might put linux as well),
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Matte, I work next to a large window.
    Build Quality and Design
    no
    ...long?
    Notebook Components
    256~ - probably SSD
    no, might get a portable one.
  2. don_svetlio
    Are you talking about the XPS 15 9550? As that should be a lot more portable than the W500. As for video editing on ULV CPUs - it's very slow and annoying. If you want any sort of real performance - XPS 15 or UX501VW
  3. Omer D
    Thanks. i guess like the 9550, but I don't know much about the XPS series. Would the glare on the XPS FHD would be ok? I have a large window behind my desk..
    As for portability, I guess as long as it's thin and relatively light i'll be fine with it. My W500 is very thick and probably around 3kg. If i put it inside, i can barely fit anything else in my bag, and the bag is still heavy.
    The UX501VW seems gorgeous..
  4. don_svetlio
    Well - the displays on the UX501 and XPS15 are bright at around 350 nits but you'd have to judge for yourself. I don't really use glossy screens so I can't give you a good idea of what to expect.
  5. Omer D
    What would you recommend as far as matte/non glare screens go? I'm used to matte screens and probably would prefer that...
  6. don_svetlio
    Budget?
  7. Omer D
    900$-1000$ can be used refurbished
  8. don_svetlio
    There are quite a few Lenovo ThinkPad T460p models on ebay - just get one with a quad-core i5 6300HQ or i5 6440HQ and an SSD. That should be more than enough. Though I'm not able to guarantee battery life due to wear and tear when buying used.
  9. Omer D
    Anything other than Thinkpads?
  10. don_svetlio
    You could try EliteBooks or Latitude E7000 series but honestly - the T460p is nothing like the W500 - it's more powerful, a LOT slimmer and a LOT lighter.
