XP installation won't copy cmnicfg.xml?
Discussion in 'Windows OS and Software' started by hooper1, Feb 17, 2008.
  1. hooper1
    hooper1 Notebook Geek
    I'm replacing Vista with WinXP Home on a Dell m1530. As it's running setup, I get this message:
    Setup cannot copy the file: cmnicfg.xml
    This is followed up by options to skip the file, retry (which doesn't work) or quit setup.
    Any idea why this is happening and how I can fix it?
  2. kegobeer
    kegobeer 1 hr late but moving fast
    During the install process, choose to format the partition. That error is related to permissions on the existing system32 directory.
  3. hooper1
    Got it! I was just about to try that. Thank you!
  4. hooper1
    Looks like that fixed the problem! Thanks!
  5. kegobeer
    Glad it worked.
