Xoticpc copper cooling upgrade?
Discussion in 'Sager and Clevo' started by DdudeACE, Jul 11, 2012.
  1. Seanzky
    Seanzky Notebook Evangelist
    Understood. I have this for external cooling: http://forum.notebookreview.com/sager-clevo/676551-effects-cooler-master-notepal-u3-w-6-fans.html
    So copper would be better then?
  2. hackness
    hackness Notebook Deity
  3. smokinokie
    smokinokie Notebook Consultant
    Profiting from the marginal design of the product. Gotta love capitalism!
  4. gkrules
    gkrules Notebook Consultant
    How much would this drop temps?
  5. aduy
    aduy Keeping it cool since 93'
    not much, i literally did the same thing, and because there is no extra circulation it mearly builds up heat into the air cavaty, so in the short term it takes longer to heat up, but then it keeps the heat longer. this is why added the few small blowers to my machine, but the airflow needs to flow from the bottom of the case out the back.
  6. Alex@XOTICPC
    Alex@XOTICPC Company Representative
    It will drop temps about 2-5C depending on what you're doing. What its doing is adding surface area to the heat transfer pipes which allows more heat to dissipate. While the heat will be in that area like aduy mentioned, it does move it away from the components which is the important thing.
  7. DdudeACE
    DdudeACE Notebook Enthusiast
    Do you have any pictures of the installed heatsinks? Are they custom built for the 9150 by xoticpc?
  8. Alex@XOTICPC
    No pics yet but hoping to get them added soon. We just put up the option today. They arent made specifically for the NP9150, we actually offer it on many models we offer.
  9. vzilla
    vzilla Notebook Guru
  10. xxpawnerzxx
    xxpawnerzxx Notebook Consultant
    you guys should offer a custom back cover that provides better air-flow :p its gonna provide better temp drops and i am sure many of us will be willing to pay ~80 for it
