XMG P507 OVERHEATING
Discussion in 'Sager and Clevo' started by Valterfsj, Nov 14, 2018.
  1. Valterfsj
    Valterfsj Notebook Enthusiast
    Hello there,
    I've noticed that my 7700hq has been running hotter and hotter whilst playing Wow and other mainstream games.
    The air temperature for sure increased a lot (now I got 32 degrees) but reaching outrageous 97 degrees is unreasonable.
    As you can see, I've using ThrottleStop and it doesn't seem to be helping. Also, look at top left, to the MSI Afterburner OSD, it doesn't show a high load, but still has an enormous temperature.
    What should I do?
    My specs:
    Schenker XMG P 507 PRO (Clevo P651HS-G)
    I7 7700HQ
    GTX 1070 Laptop(not Max-Q)
    AUO52ED FHD Display G-Sync
    8Gb HyperX Impact
    SSD 500gb M2 Crucial MX500
    SSHDD Firecuda 1TB
    Also, I've been running at the maximum fan speed while gaming, trying to plummet those temperatures. Using the laptop on top of a thick and flat glass desk.
    PS: I've noticed that I'm Idleing on 55 degrees.
  2. Danishblunt
    Danishblunt Guest
    Repaste with IDDiamond and you're back to the normal temps.
    Vasudev and Dr. AMK like this.
  3. Valterfsj
    Unfortunately, where I'm currently living(Brazil) I can't find neither IC Diamond nor Thermal Grizzly (this one I found, but for almost 100usd). Also, with the current customs delays and taxes, importing is not an option.
    Does Artic Silver 4 or Artic Ceramique 2 would help? Those I can find for a good price and stock
  4. Danishblunt
    Danishblunt Guest
    Artic silver 5 or MX4 are both decent as well, they may not be as good, but they shouyld do the trick I suppose.
  5. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    Nothing like ICD but AS will still get you significant benefit over stock (at least compared to what Intel was shipping with).
  6. Meaker@Sager
    Mx4 can pump a bit but does perform well.
  7. Chastity
    Any Gelid Extreme in your area?
    Vistar Shook likes this.
  8. Valterfsj
    I managed to find Arctic Silver 5, Arctic Ceramique 2, Cooler Master GelMaker Nano, some Thermaltake ones(tg3 tg4 tg7) and Akasa 450 and 455.
    Of those, as far as I know, only AS and CM nano is good(both expensive as hell, but I'm willing to pay that to drop down my temperatures) and I would better be served with toothpaste than the other ones.
  9. Meaker@Sager
    Ceramique is not terrible iirc.
  10. Vasudev
    Both are absolute junk and will need repasting every 2-4 weeks.
    Ask @Vistar Shook
