X3Plus V3 Starcraft 2- Ultra setting = slow frame rate :-(
Discussion in 'Gigabyte and Aorus' started by coolesnce, Feb 20, 2015.
  1. coolesnce
    coolesnce Notebook Enthusiast
    I been enjoying my X3 V3 for gaming . I installed StarCraft 2 and ran in ultra setting running 1920 x 1080. I was running fine then as i had more things on the screen it started to stutter and creep to an unplayable frame rate. Dropping the setting to moderate helped. I was surprised that the X3 Plus with tne new Nvidia 9xx card couldn't handle a game that's a few years old.
  2. bernieyee
    bernieyee Notebook Evangelist
    Blizzard games are always more CPU intensive. I would check your temperatures.
  3. coolesnce
    Temps are never above 72 C for GPU and 75 C for CPU
  4. LVNeptune
    LVNeptune Notebook Virtuoso
    You sure it's launching using NVIDIA and not Intel?
  5. coolesnce
    yes I am pretty sure. Plus I don't think Starcraft two with launch and play correctly using just the lntel card
  6. sisqo_uk
    sisqo_uk Notebook Deity
    if you havent already put the fans on maximum. and into high performance mode profile. it thats will guarantee you full power non stop.
  7. coolesnce
    Thats how I have it set and been able to keep my temps low. Open to any other suggestions though.
  8. sisqo_uk
    ummm id say reinstall drivers but honestly no idea about that game from any experience really. i just didnt expect it to choke on that game when i strained my card and it was fine besides one hiccup that was the games fault.
  9. LVNeptune
    I could go for some lunch.
  10. wanderer82
    wanderer82 Notebook Guru
    Hi Neptune, is there a way to tell which card is being loaded for a game? My star citizen is very choppy, not sure which card is being used.
    Thanks!
