X301 LED screen problem
Discussion in 'Lenovo' started by Unkgd, May 24, 2009.
  1. Unkgd
    Unkgd Newbie
    Just looking to see if this problem has happened before. I have a 1.5 month old X301 with the LED screen and initially it worked well. After about 3 weeks of use the screen will become fuzzy - as if the interlacing is not working and eventuallyt becoming unreadable. This typically occurs after being used for a few minutes - to a few hours - one either battery or AC power.
    If an external monitor is connected at the same time as the screen is having problems - the external monitor will be fine with no screen corruption. All computer funtionality remains - it is merely the fact that the notebook screen becomes unreadable.
    The screen can become readable by pressing on on various parts of the notebooks - but it is completely random as to where to apply pressure.
    I have sent it back once for repair and the motherboard was replaced. It is scheduled to go back again (as it failed out of the box) and I was hoping to provide some additional information if it is out there.
    Thanks.
  2. bsodder
    bsodder Notebook Evangelist
    May be as simple as an LCD connector cable left loose when the planar was replaced - not an uncommon scenario, unfortunately. Does need to be sent back, however.
