x220 9.5mm drive
Discussion in 'Lenovo' started by anarky321, Jul 27, 2017.
  1. anarky321
    anarky321 Notebook Deity
    quick question - considering downgrading from x230 to x220 - my 1TB msata, battery slice and 2TB 9.5mm drive will swap over without issues right? they are identical chassis?
  2. tongdakfiend
    tongdakfiend Notebook Consultant
    I'm not sure about the 2TB 9.5mm drive. I believe it only fits 7mm drives, but not 100% sure. I believe I did read somewhere that you could cram a 9.5 drive in, but you may want to do some research on that.
  3. anarky321
    the x230 has to be crammed too but i didn't have to trim anything
  4. ZaZ
    To what end?
  5. Starlight5
    Starlight5 I'm a cat. What else is there to say, really?
    @anarky321 if you managed to cram 9.5mm drive inside X230, you will manage to cram it inside x220 as well - one way or another. Chassis is identical except DP on X220/T vs miniDP on X230/T, and VGA port differs a little bit.
  6. anarky321
    better keyboard (imo)
  7. Starlight5
    @anarky321 there's a EC firmware mod that allows to fully utilize classic keyboard on X230. X220 is better than X230 only in easier whitelist removal (allows directly flashing modded BIOS) and wider third-party battery support.
    huntnyc likes this.
