x200 will not power on
Discussion in 'Lenovo' started by tuan209, Mar 5, 2010.
  1. tuan209
    tuan209 Notebook Guru
    hi guys,
    I am not sure what is happening here but it may seem that i have broken my laptop. I installed a new screen on my laptop a few days ago, and it worked fine but there was a buzzing noise. This morning I swapped back in the old lcd and in the process I must have done something wrong. After installing in the lcd, my notebook will not power on any longer.
    The power LEDs turn on but nothing else. Could this be a result of a damaged inverter or something else?
    Any suggestions?
    Tuan
  2. jaredy
    jaredy Notebook Virtuoso
    Did you try reinstalling it to make sure everything is plugged in properly?
    When you say nothing else is on do you mean no hard drive activity? Because if the screen was installed incorrectly, obviously it nothing would show up.
    A couple people have done LCD swaps here so they could probably help you. Good luck.
  3. tuan209
    Yea I doubled check to see if everything was installed correctly and it seems to be. I connected my external lcd to the laptop and nothing shows up either.
    When I turn on the the laptop, the power leds will light but it does not seem to boot up.
  4. Iron Eagle
    Iron Eagle Notebook Evangelist
    Are you certain it is not powered on? I mean, when mine powers on I can barely hear anything...
    Perhaps you can try an external monitor?
  5. jaredy
    OP said he tried an external display. Pop out the battery hold down the power button and put it back in. Then try to turn it on.
  6. tuan209
    Thanks for the suggestion but it isnt working. It looks like the power is cut off to the rest of the system. I opened the whole chasis up, and when I powered the laptop on, the fan spins momentarily and dies. If I leave the power on, the laptop gets warm. I dont know if that is indication that the cpu is on or not.
  7. lead_org
    lead_org Purveyor of Truth
    did you wear any static discharging device when you opened the laptop up? there is a chance you fried the motherboard.
  8. perfectionseeker
    perfectionseeker Notebook Evangelist
    ok it looks like I will not be replacing any screens ... not worth it if laptop dies. I would say take it in for repairs.
  9. tuan209
    Thanks guys.
    I have tried everything and the thing will not turn on. I guess I can either get fixed or replace it.
    From what I have described, how much would it cost me to get it fixed? Or should I just purchase a new laptop? :(
  10. lead_org
    it is probably cheaper to just get a used x200 laptop.
