Would a M.2 and 2 SSDs fit inside a SAGER NP9175 (CLEVO P775TM-G)?
Discussion in 'Sager and Clevo' started by Xavvy, Jul 21, 2018.
  1. Xavvy
    Xavvy Notebook Guru
    I was wondering, can the SAGER NP9175 (CLEVO P775TM-G) hold 2 2.5" drives? If yes, could I install a third M.2 SSD into it?
    I purchased a 1TB Samsung 970 pro (for gaming) and wanted to install a 2 TB Samsung 860 Evo with it (For video editing), but it looks like getting 2 1TB drives is a bit cheaper than one 2TB drive.
    My idea is to RAID 0 two 1TB SSDs instead and install the OS onto it for use for all my non-gaming stuff, then install an OS onto the 970 pro (as a backup) and move all my games to that drive. Is this possible? Any help is appreciated. Thanks!
  2. Meaker@Sager
    Yes, check out our configurator and you can spec up the system to show what it can fit.
    Xavvy likes this.
  3. Xavvy
    Xavvy Notebook Guru
    On the configurator now! Sweet! Thanks for the info!
  4. Meaker@Sager
    No problem, sounds like a sweet setup.
    Xavvy likes this.
  5. Xavvy
    Xavvy Notebook Guru
    Done and done! The 2 SSDs will be arriving today and the laptop will be here on tuesday! All that's left to do now is wait. I'll be sure to keep you guys posted when I set it up!
  6. Meaker@Sager
    Nice, enjoy :)
