Worth buying a 5820K and a RX 480 (8GB) for €1000/$1100 (for 1440p)?
Discussion in 'Desktop Hardware' started by jaug1337, Aug 19, 2017.
Tags:
Is it worth it?
  1. Yes
    66.7%
  2. No
    33.3%
  1. jaug1337
    jaug1337 de_dust2
    Hi folks,
    I need advice on whether I should buy this monstrosity of a machine for the said price point, it is second hand.
    I am going to be gaming on my AOC U3477PQU (3440 x 1440).
    • SSD: 120GB SSD Corsair LS
    • CPU Cooler: Corsair H105 Hydro Series
    • RAM: Crucial DDR4 Ballistix Sport 8GB
    • CPU: Intel Core i7 5820K
    • Motherboard: ASRock X99M Extreme4
    • GPU: RX 480 AMD 8GB Sapphire
    • Case: Corsair Carbide Air 240 Cube, Black
    • PSU: HX850 Corsair Gold Certified PSU
    Thanks in advance!
  2. don_svetlio
    don_svetlio Notebook Virtuoso
    I mean, if you can live with medium-high settings in games, sure. The 480 is essentially the same as a 980 from last gen.
  3. jaug1337
    jaug1337 de_dust2
    I am looking into upgrading the GPU at some point and adding an additional 8GB of RAM.
    I am not picky with in-game settings, I will be overclocking heavily and I'd just like to play games on my monitor.
    Thanks for the reply.
  4. don_svetlio
    Games will easily be playable. Even demanding ones such as Witcher 3 will run well at medium settings.
    And you have a good baseline - can easily upgrade to a Vega 56 or 1080 in the future.
  5. jaug1337
    jaug1337 de_dust2
    My thoughts precisely.
    However, I might be on to getting a 7700K and a 1080 strix for 400€ more approx $470, AND a asus 240hz pg258q included in that price.
    Jesus christ am I confused.
  6. don_svetlio
    The 7700K is currently horrible value. The upcoming 8700K is going 6-core/12-thread and i3s are becoming quad-cores and one of them is unlocked. The 7700K's resell value will drop by 3x very very soon. If you want a current platform - Ryzen or wait 2 months to see what Intel come up with. Kaby lake is just not good anymore.
  7. jaug1337
    jaug1337 de_dust2
    I thought so.
    Man is it a bad time to build a PC right now. Prices are through the roof.
  8. don_svetlio
    Yup. GPUs, SSDs, RAM - all of those are going up in price. Though at least CPU cores are getting MUCH cheaper.
    My best advice would be to either pick up the system in the first post or build a R7 1700 + B350 board setup with a 2nd hand 980/970/390(X) and a good PSU (since those tend to last a LONG time). Then, when GPU prices normalize, pick up a 1080 or (if something new is coming till then) wait for Navi/Volta.
    EDIT: My logic: AM4 support is confirmed until at least 2020 so 2 more CPU generations on it - plenty of upgrade path left.
  9. jaug1337
    jaug1337 de_dust2
    Ryzen is unfortunately ungodly expensive in Europe.
    The build above should have me lasting a good while, as 4 cores didn't suffice for streaming and computing for school, so a 6 core should do the job, planning to heavily OC it.
    The GPU can be upgraded anytime, so there's that.
    The Ryzen build will have to be postponed slightly, maybe until Zen 2 comes out, Intel is spitting CPU's out faster than lighting, and AMD is launching new architectures faster than they can implement it.
  10. don_svetlio
    Last word of advice. The 5820K (Haswell-E) and Ryzen are soldered meaning lower temperatures and less hassle. Intel current and future CPUs use paste. So if you are an overclocker, Skylake-X, Kaby Lake and likely Covfefe Lake all need a delid before any OCing is performed. But I'm sure you've read up on the subject.
    jaug1337 likes this.
