Wlan Disabled...no Network Adapter???
Discussion in 'HP' started by yake90, Oct 13, 2008.
  1. yake90
    yake90 Newbie
    I just reformated my HP Pavilion dv6000 and am currently running it on Vista Ultimate Service Pack 1, I try to connect to the internet using WIFI but when I use HP Wireless Assistant it says "Wireless LAN" DISABLED, "This device has been disabled in Windows Device Manager. To enable this device, use Windows Device Manager." I tried to do this but there is no network adapter. my wireless light switch is ORANGE where it should be BLUE. I dont know what to do so can anyone help me?
  2. kuncheesh
    kuncheesh Notebook Evangelist
    after reinstall did u reinstall the drivers needed ??
  3. jcovelli
    jcovelli Notebook Deity
    yep.. you need to download the drivers for the wireless card
  4. yake90
    yake90 Newbie
    I think i have done this, I went to the hp website off my other computer, looked up the drivers for network under pavilion dv6000 and installed them on my laptop but still nothing...
  5. TwiztOG43
    TwiztOG43 Notebook Evangelist
    HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 Series Notebook PCs - HP Limited Warranty Service Enhancement
    The following symptoms apply to the dv6000, dv9000 and v6000 series notebooks:
    The notebook does not detect wireless networks and the wireless adapter is not detected in the Device Manager.
    There is no video on the computer LCD panel or external monitor.
    The notebook has no power and no active LEDs.
    The notebook does not start.
    The battery charge indicator light does not turn on when the battery is installed and the AC adapter is connected.
    The notebook issues a single beep during boot indicating no power.
    The external monitor functions but there is no image on the notebook LCD panel.
    im afraid you might be seeing the early signs of a motherboard failure.
    that is exactly what happened to me, first a a few weeks without the network adapter working then the flickering screen then no boot up what so ever.
    even if your out of warranty, HP will cover it for free for 2 years at the start of your warranty.
  6. yake90
    yake90 Newbie
    so what should I do then, talk to hp or go to a store?
  7. TwiztOG43
    call HP or have an online chat with them
  8. yake90
    yake90 Newbie
    thanks a lot, wow I cant believe this could happen
Similar Threads - Wlan Disabled Network
  1. JAMM0N
    119
  2. tanzmeister
    29
    1,761
