Wireless Switch Setting Utility problems (Windows Vista)
Discussion in 'VAIO / Sony' started by mcunha71, May 25, 2007.
  1. mcunha71
    mcunha71 Notebook Geek
    Wireless Switch Setting Utility insure (Windows Vista)
    Hi,
    I’m encountering a few problems with this software (ver.3.5.00.11270).
    Every time I lock my notebook (SZ340, Vista Business express upgrade) I got WiFi disconnected when unlock the user.
    This also happens when I switch users.
    I’m sure this software is the cause of the problem, because the disconnection only happens if WiFi Switch Setting Utility is running. If I close the software there isn’t disconnection problem when switch users or lock/unlock the computer.
    Any solution to this? If I uninstall this software has another way to keep the Bluetooth off and turn on easily when needed?
    Thanks in advance.
  2. sylonien
    sylonien Notebook Evangelist
    Hm well I don't think mine disconnects when I lock it - but it does when it goes on Standy/Hibernate - can't believe it does it for Standbye though. Bit annoying. Might just be a Vista problem - not everything is quite running in order yet. :(
