Wireless Problem
Discussion in 'Dell' started by pesttech, Aug 18, 2006.
  1. harddoom
    harddoom Notebook Geek
    i had the same problem with e1705 this worked for me:
    Hey, if you had the same problem as i did, the problem was that i had the power management software on for the device. So this is what i did to fix it. Normally the issue seems to come out of standby, or especially when it detects another network.
    You do this
    1. Disable Wireless Zero Service (optional for me)- this is the windows wireless organizer, i like to use it cause it allows for less processes, and a cleaner install. If u disable it by using msconfig, you should install the intel application and let that moderate ur wireless.
    2. Go down to your wireless adapter (Right click my computer-properties-hardware and then device manager, it should be under network adapters) and open properties. Then go to the power management tab and make sure 'Allow the computer to turn this device off to save power' is unchecked.
    3. Disable power management restrictions
    Have highest performance checked in powermanagement
    lemme know if this helps.
  2. compsavy
    compsavy Notebook Deity
    I have the same wireless router/modem and if the firewall is on. On the router disable it because it will make sites much slower.
  3. billionaiire
    billionaiire Notebook Guru
    Decrease your router's and cable modem's (if you have one) MTU setting to 1492 packets. DrTCP program allows to change the MTU for the System. Your wireless router settings page should have a MTU setting tab. PPPoE uses 1492.
    This might just help.
    But if your notebook is intermittently detecting the wireless network and you are able to work, then first of all, try updating all the necessary drivers first.
  4. pesttech
    pesttech Newbie
    Want to thank everyone for the replies and help but I just figured something out and this is going in an entirely different direction.
    I was goofing around the westell site and saw that the Westell 327M Verizon sent me was an IEEE 802.3. The Dell 1390 in my laqotop is if I'm not mistaken is an IEEE 802.11 and I saw this
    "The Dell Wireless WLAN Card works with any IEEE 802.11 Wi-Fi CERTIFIED™ access point or wireless client network adapter."
    Is this the problem I'm having with my connection issues?
  5. ludayoda
    ludayoda Notebook Guru
    I would suggest just getting a new wireless router...they are fairly cheap nowadays. If this fixes the problem, then your router was probably the problem.
  6. pesttech
    pesttech Newbie
    Finally got it resolved and now my connection spanks. After I bought a new router/modem and still having issues after updating drivers called Dell and asked for a box to return it in. CS said if they gave me $115 and connected me with hardware to finally fix the issue would I keep it and I said sure.
    Anyway 2/12 hours later going through Hardware I got connected to someone in Wireless that finally fixed my issue. Basically the LAN card goes to sleep after a certain non use time and he went into power management and disabled power management and something else. Never thought it was something so simple.
    Anyway just an FYI for anyone else having connectivity issues or their wireless dropping off.
