wireless linksys help
Discussion in 'Networking and Wireless' started by faith4, Jul 24, 2006.
  1. faith4
    faith4 Notebook Enthusiast
    hi, after installing the cd that comes with the software "wireless - G Broadband Router, Linksys 2.4GHZ.
    wat else do i do next to enable the wireless connection ?
    cuz right now if i unplug the cable , it wont let me connect to the internet.
  2. kidA
    kidA Notebook Deity NBR Reviewer
    try going to 192.168.1.1 or 192.168.2.1
    I cant remember which is the default for linksys, and look at the settings. If it asks for a password and login, its probably "admin" an pw "password" check the owners manual.
  3. Thaenatos
    Thaenatos Zero Cool
    192.168.1.1 is the default. keep the plug in and open a IE window and in the address bar type in 192.168.1.1. Then a username and password prompt will pop up. Skip to the password and typ "admin" and it will let you in. After that look for a wireless tab and enable wifi, also look for encryption and use WPA type in a password and you should be done. Also make sure the SSID is something youll recognize when roaming for hotspots at home. When you find yours it will prompt you for a network key and enter the password you made for the wpa encryption.
    If you are still not getting internet make sure your router is pulling an IP from the ISP. That will be under another tab in the router interface. just select release and renew.
  4. faith4
    when i go on that webpage, it wont allow me to save settings, and an error is located at the bottom of the webpage.
    wat to do ?
  5. Thaenatos
    Thaenatos Zero Cool
    if the router's firmware wont accept the change then I would call cisco/linksys to see what they have to offer.
  6. faith4
    nvm, i had the firewall on, sry guys.
    but thx for telling that ip web address, i got it set up.
    once again , thanks very much, i appreciated :)
