wireless card upgrades
Discussion in 'Hardware Components and Aftermarket Upgrades' started by kojack, Aug 27, 2020.
  1. kojack
    kojack Notebook Virtuoso
    Can I upgrade my wireless cards to newer faster versions? I know in my 3168 it only has a 2.4gb . I was hoping to install a new card with 5g as well.
  2. tilleroftheearth
    Is that 3168 a WiFi card or a notebook model?
    If it's the card, it does have the 5GHz band.
    If it's the notebook (Dell?) if you can get it apart, and it's not soldered, you should be able to upgrade it to the Intel AX200.
    Starlight5 and kojack like this.
  3. kojack
    OK. It's the 11 inch dell 2 in 1.
  4. kojack
    Is it only certian cards that will work, or any card that fits the slot will work? I may swap my 13 5000s wireless card for something more up to date and faster.
  5. TheQuentincc
    TheQuentincc Notebook Evangelist
    I don't think Dell have a whitelist for theses devices unlike some older hp or lenovo laptop
  6. kojack
    Ok, so that means I can swap to a new better card. Also, my inspiron 11 3000 has a qualcom atheros 9565 card. is this upgradeable? This card has only 2.4ghz and I would hope to swap to a 5ghz card.
  7. jeffreyC
    jeffreyC Newbie
    They did up to a few years ago. (about 2016 or was it 2014?)
    tilleroftheearth likes this.
  8. KING19
    KING19 Notebook Deity
    Search on EBay to see what wifi cards will be compatible for your system. Go no less than Wireless AC (Wifi 5) since they have 5GHz support by default if possible.
    But with your system you probably going be stuck with Wireless-N and if so make sure its a dual band card.
  9. Starlight5
    Starlight5 Yes, I'm a cat. What else is there to say, really?
    @kojack did you verify that 3168 isn't soldered to the motherboard? Check service manual or disassembly photos or videos to make sure.
    kojack likes this.
  10. tilleroftheearth
    @kojack forget a mere '5GHz' capable card.
    Just buy the Intel AX200 if you can get into the computer and its upgradeable.
    In other words, don't do a half a$$ed job. :)
