Windows 7 installation help for Intel Skylake and Kaby Lake laptops
Discussion in 'Windows OS and Software' started by Atom Ant, Apr 13, 2017.
  1. steberg
    steberg Notebook Evangelist
    Vasudev likes this.
  2. Vasudev
    I downloaded it using Slow or free download. It downloaded at ISP advertised speed of 10 Mbps.
    steberg likes this.
  3. saturnotaku
    Don't have a license key for Windows 7. I do have one for W10 Enterprise, so the lite version of that, which is linked in the thread you posted, is of interest.
  4. Vasudev
    Its a pro version.
  5. LaptopNut
    LaptopNut Notebook Virtuoso
    Have you already installed Windows 7 SP1, rollup patch (sort of SP2), and reenabled the blocked updates? On my laptop, I just got them from the Windows 10 Driver CD, browsed and installed directly from there. You should either try the Driver CD that came with your laptop directly, or use the information on it to source the Driver.
    Vasudev likes this.
  6. Token CDN
    Token CDN Notebook Consultant
    So, I tried the version that @Vasudev linked. Worked fine-ish (still needed to install USB 3.0 drivers after install), except for one big problem. After some (admittedly half-assed) searching, it seems there is no such thing as Intel SST audio drivers for Win 7. SST is totally useless IMO, but I haven't had any joy trying to get any other driver (read: non-SST) to work. Anybody know of a work around? I could just use my USB DAC 24/7, but that's not entirely convenient
    Vasudev likes this.
  7. Vasudev
    Do you mind telling me what exactly is Intel SST? I thought it was speed shift or something.
  8. Token CDN
    Vasudev likes this.
  9. Vasudev
    Thanks. Looks like they promise Dolby and HD capabilities and I see no drivers.
    Check this thread out and try installing the lenovo's version of SST https://communities.intel.com/thread/92149
  10. Token CDN
    Have my doubts that those drivers would work (seems they're made for Atom type processors)
    Honestly, I'd rather ditch the SST crap altogether - it does nothing useful for me on Win 10 - and figure out how to use regular ol realtek HD audio drivers (or similar) instead.
    Probably the only (practical) option is to use a USB/bluetooth device
    I did restore my Win10 so I can't really try anything out atm anyways. If I can find a better option for audio, I might try Win 7 again.
    I also totally forgot that you can't do anything on Win 7 without having to reboot:D
    Vasudev likes this.
