Windows 7 installation help for Intel Skylake and Kaby Lake laptops
Discussion in 'Windows OS and Software' started by Atom Ant, Apr 13, 2017.
  1. cincinnatus
    cincinnatus Notebook Enthusiast
    Sad to hear that.
    Do you have any yellow alert in "device manager"? (except the touchpad).
    I would install Windows 7 drivers (I got mine from the previous laptop model that supported it) and avoid Windows 10 drivers (even if they install fine).
    This is what I would try, let us know if it gets any better...
  2. Atom Ant
    Atom Ant Hello, here I go again
    Have you used my modded driver that I linked in my first post? You should not experience any performance loss with it.
  3. Zazazas
    Zazazas Newbie
    So is it possible to install 7 on an i5 8300h with a 1050 on a h370m chip? I keep on getting conflicting opinions saying that no you can't or you need a pci controller or something else.
  4. Atom Ant
    No drivers for I5-8300H exist yet, so you have to go with Windows 10.
  5. julian167
    julian167 Newbie
    Unfortunately no. I tried everything I could for the last few months before giving up on this.
  6. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Please help, the intel hd 630 driver causes me a blackscreen after I reboot, no matter which driver I try to install, always does the same thing.
  7. Papusan
    It worked before?
    And you are sure you haven’t got new updates from Microsoft?
  8. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    never worked, I am using win7 sp1 image. literally this is the last step in configuring my blade to run win7, I even managed to get the i2c touchpad to work!
    Edit
    Upon further investigation, everything works via HDMI out.....just the internal display seems to be having problems. No problems in device manager when connected over hdmi, anybody run into something like this before?
    hmscott likes this.
  9. Atom Ant
    Which version driver are you using, modded by who? Also which generation is your CPU?
  10. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    the driver that is linked in the original post. running 7700hq/hd 630
