Windows 7 installation help for Intel Skylake and Kaby Lake laptops
Discussion in 'Windows OS and Software' started by Atom Ant, Apr 13, 2017.
  1. Atom Ant
    Atom Ant Hello, here I go again
    Thanks guys, especially for steberg who provided the latest modded Intel IGP driver which works solid and stable. Windows 7 is great, especially after Windows 10...
    hmscott and steberg like this.
  2. rhinoceros
    rhinoceros Newbie
    hmscott likes this.
  3. Atom Ant
    I adjusted the guide with adding PCIe/NVMe drivers and integrating Simplix Pack into the Windows 7 image. It is useful, because Windows 7 with Samsung EVO 960 PCIe SSD is awesome, blazing fast!
    hmscott likes this.
  4. rhinoceros
    rhinoceros Newbie
  5. steberg
    steberg Notebook Evangelist
  6. dcg1k
    dcg1k Newbie
    Hello steberg, I'm also interested in your modded inf file. Can you send me PM plz?
    thanks a lot!
  7. Atom Ant
    You can read now straight at the Intel's communities how to make Win7 driver. This also means some smart guy showing the trick directly to Intel. I Hope for Coffee Lake we can figure out a different trick to install drivers...
  8. dataworx
    dataworx Newbie
    I was linked to this guide since I am trying to install Win 7 64 bit on a HP Pavilion, with 7th Gen. Intel Kaby Lake I3-7100U processor, preinstalled with Win 10.
    I had a problem installing via USB (device drivers missing story) so I installed as a dual boot via DVD to a new partition. The install went fine, apart from the system complaining that 'Partitions on the disk are not in the recommended order'.
    I have since installed Wi-Fi, graphics and chipset drivers (chipset I did after Wi-Fi and graphics, because I couldn't find them at first). I am now stuck, with non-working USB ports and Bluetooth. Going through this guide, I see the recommendation to slipstream Windows 7* USB 3.0 Creator Utility in the USB install.
    Looks like I did a few things in the wrong order (ie chipset first, not last), so I'm happy to redo the installation. Can one of the guys here explain how I should prep the DVD install to ensure functional USB ports, or is it only going to work with a USB install? And finally, how am I going to get Bluetooth going - I installed drivers from the Intel site but there is no sign anywhere of the Bluetooth device.
    Edit: after further reading and now understanding the process better, it appears that I can slipstream the Intel USB driver utility with the Win 7 install USB (since I will install from within Win 10) as a dual boot. Is my understanding of this correct? If so, my only problem seems to be the BT driver - it seems that is allied somehow to the Wi-Fi driver but I haven't yet figured that out.
  9. Atom Ant
    Yes, you must slipstream USB 3.0 drivers into the installation media. I recommend to use pendrive, because slipstream to DVD is more difficult. Also if you want to use Win 7 and Win 10 in separate partitions, it would be wiser first install Win 7 than 10.
    With Bluetooth driver I also struggled once, but figured out first I need to install the correct Wireless driver, than the bluetooth. Actually I just checked my device manager and I see I have the standard Microsoft bluetooth emulator installed, so might the solution was not to install any bluetooth driver.
  10. dataworx
    dataworx Newbie
    Thanks for your input Atom Ant - I was hoping you'd pick this post up.
    I have Win 10 already installed, so I'd prefer to just add Win 7, unless that is likely to create a problem (is this the cause of the message 'Partitions on the disk are not in the recommended order' when I first tried it?).
    The link you have given is to a wireless driver different to what I initially installed (I used v19.60.0 PROSet64 Win 7), so hopefully this is where I went wrong with Bluetooth.
    I'll have a chance to try this install tomorrow, once I've prepped the USB. I'll let you know what happens.
