Windows 7 installation help for Intel Skylake and Kaby Lake laptops
Discussion in 'Windows OS and Software' started by Atom Ant, Apr 13, 2017.
  1. Atak_Snajpera
    Atak_Snajpera Notebook Enthusiast
    How much free space do you have on D:
  2. Mr. Fox
    Sometime MSMG Toolkit is uncooperative, for reasons not understood, but doing the WIM mods on a different drive has always caused it to work right for me when that happens. Maybe that is what is going on here?
    Vasudev likes this.
  3. Raiderman
    Raiderman Notebook Deity
    Everything is on D. I have 2.5 tb free
  4. Mr. Fox
    Try moving the whole process and the files to the C:\ drive and see if it completes properly. I have had this happen multiple times with MSMG Toolkit. I normally do everything on D:\ as well. Not sure why it matters, but it seems to. Just weird that it is random. @Phoenix has experienced the same thing.
    Maleko48 and Vasudev like this.
  5. Raiderman
    I will give that a try.
    Edit: Still the same result, only it takes about a third of the time :)
    Maybe its not a clean install.wim. I know I had an untouched 64x Win 7 sp1 iso somewhere, but may have lost it. Maybe MDL has some mirrors of clean ISO images, as Microshaft doesnt supply them anymore, even with a legit key.
  6. Raiderman
    @Atak_Snajpera Is there a way to add modified .dll files using this program? lIKE Imageres.dll, and shell32.dll. I would like to create a custom install of how I set everything up.
  7. Raiderman
    Still getting errors with moving to C drive, and a freshly downloaded untouched ISO from MDL.
    [2018-01-30 09:49:16]
    [2018-01-30 09:49:16] Deployment Image Servicing and Management tool
    [2018-01-30 09:49:16] Version: 6.1.7600.16385
    [2018-01-30 09:49:17] Image File : C:\Users\CPHome\Desktop\Windows_7_Image_Updater\Image\sources\boot.wim
    [2018-01-30 09:49:17] Image Index : 2
    [2018-01-30 09:49:18] Saving image
    [2018-01-30 09:49:23] Unmounting image
    [2018-01-30 09:49:28] The operation completed successfully.
    ----------------[ install.wim -> Windows 7 ULTIMATE ]----------------
    [2018-01-30 09:49:28] Deployment Image Servicing and Management tool
    [2018-01-30 09:49:28] Version: 6.1.7600.16385
    [2018-01-30 09:49:34] Mounting image
    [2018-01-30 09:50:02] The operation completed successfully.
    [2018-01-30 09:50:02] Deployment Image Servicing and Management tool
    [2018-01-30 09:50:02] Version: 6.1.7600.16385
    [2018-01-30 09:50:05] Image Version: 6.1.7600.16385
    [2018-01-30 09:50:06] Searching for driver packages to install...
    [2018-01-30 09:50:11] Found 163 driver package(s) to install.
    [2018-01-30 09:50:11] Installing 1 of 163 - C:\Users\CPHome\Desktop\Windows_7_Image_Updater\Windows7\Drivers\x64\Alcor Micro Smart Card Reader\SZCCID.INF: Error - An error occurred. The driver package could not be installed.
    [2018-01-30 09:50:11] For more information, check for log files in the <windir>\inf folder of the target image.
    [2018-01-30 09:50:11] Installing 2 of 163 - C:\Users\CPHome\Desktop\Windows_7_Image_Updater\Windows7\Drivers\x64\Alcor Micro USB Card Reader\AmUStor.inf: Error - An error occurred. The driver package could not be installed.
    [2018-01-30 09:50:11] Installing 3 of 163 - C:\Users\CPHome\Desktop\Windows_7_Image_Updater\Windows7\Drivers\x64\Alpine Ridge USB\USBController\ausb3xhc.inf: Error - An error occurred. The driver package could not be installed.
    [2018-01-30 09:50:11] Installing 4 of 163 - C:\Users\CPHome\Desktop\Windows_7_Image_Updater\Windows7\Drivers\x64\Alpine Ridge USB\USBHub\ausb3hub.inf: Error - An error occurred. The driver package could not be installed.
  8. Atak_Snajpera
    This may sound silly but you could try updating on virtual machine with win10 ;)
    I have no idea why it does not work on your pc.
  9. Atak_Snajpera
    I have just updated Windows 7 Image Updater
    v2018.02 - Change Log
    Code:
    Added: Support for splitted images (install.swm)
    Added: Support for compressed images which use LZMS-solid algorithm
    Added: Automatic splitting of install.wim if file size is bigger than 4095 MiB (FAT32 Compatibility)
    Added: Automatic recompression using the strongest algorithm supported by selected installer (2009 [Win7] installer supports only LZX while latest [Win10] much more efficient LZMS-solid)
    Added: Automatic import of any files to selected edition(s) via Import folder (Folder structure after importing is maintained!)
    Updated: Tools (7z v18.01 , DISM 10.0.16299.15 , oscdimg v2.56, rufus v2.18.12.13 , wimlib 1.12.0)
    LINK is the same
    https://forum.videohelp.com/threads...SkyLake-KabyLake-CoffeLake-Ryzen-Threadripper
    Mr. Fox and Raiderman like this.
  10. saturnotaku
    Can you add drivers for the Killer E2200/2400/2500 Ethernet adapters in a future update? Your pack already contains some for their Wi-Fi counterparts.
