Discussion in 'Windows OS and Software' started by Ultra Male, Jul 31, 2015.
  1. 6.|THE|1|BOSS|.9
    6.|THE|1|BOSS|.9 Notebook Evangelist
    Count me in! :D
    Vasudev and Ultra Male like this.
  2. Ultra Male
    Ultra Male Super Tweaker
    you need to learn the Ultra Male lingo which you will see across various posts:
    taptop = laptop
    tootube = YouTube
    just to name a few, I can't remember them all right now as it's 5:37 AM here in Dubai [​IMG]
  3. Vasudev
    Done!
    It was 1.30 AM in India. Added a new bigger table, now I am enjoying it but cable management is a mess and now I don't have enough space for my headphones, adapters and Mifi router.
    Ultra Male and 6.|THE|1|BOSS|.9 like this.
  4. Ultra Male
    Fix for Windows 10 Can’t See Other Computers on the Network:
    1) Press the CTRL + R keys on your keyboard to pull up the Run Dialogue Box
    2) Type Services.msc then hit Enter
    3) Scroll down to the Service called: Function Discovery Provider Host then double click on it and change its startup type from Manual to Automatic (Delayed Start)
    4) Go to Control Panel > Programs and Features > Turn Windows feature on or off
    5) Scroll down till you see SMB 1.0/CIFS File Sharing Support then expand it by clicking on the + sign.
    6) Check the box next to SMB 1.0/CIFS Client then hit OK to enable that feature.
    7) Reboot your computer
    BALTAGY and Vasudev like this.
  5. Vasudev
    I think @Mr. Fox was looking for it since 4 months. I guess he'll be happy!
    Ultra Male likes this.
  6. Ultra Male
    How to Disable the Windows 10 Startup Delay:
    After Windows loads up, it doesn't start loading your startup apps immediately as to dedicate more resources to load system services and files. If you have a fast computer and particularly an SSD, you can disable this feature and have even your apps start loading instantly the moment Windows boots up.
    To do this, simply download the following ZIP file which contains to registry entries, one to disable the startup delay and another to enable it. So double click on one of the registry files to disable or enable the delaying of fast startup and reboot.
    Download Startup Delay Registry Files
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Serialize]
    "StartupDelayInMSec"=dword:00000000
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Serialize]
    "Startupdelayinmsec"=-
    BALTAGY likes this.
  7. Vasudev
    I believe this was posted long time ago and I'm using that on PCs by default.
    NIGHTMARE likes this.
  8. Ultra Male
    little tip for you, you are not *obliged* to comment on every freakin' post I make! [​IMG]
    FTW_260 and Vasudev like this.
  9. BALTAGY
    BALTAGY Newbie
    I think you don't need to enable SMB 1.0 you only need AllowInsecureGuestAuth
    Code:
    reg add HKLM\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters /v AllowInsecureGuestAuth /t REG_DWORD /d 1 /f
    Try it, without enabling SMB 1.0 and see if it helps
  10. xxEIEIOxx
    xxEIEIOxx Notebook Enthusiast
    The disable appears to add a value to the HKEY_LOCAL_MACHINE branch of the registry where the enable looks like it is set to remove said value from HKEY_CURRENT_USER. I expect that the enable therefore does nothing. You may want to make those match. Also, I found this download on Majorgeeks, so same issue there. I like the idea though, I will be testing this out.
