Discussion in 'Windows OS and Software' started by Spartan@HIDevolution, Jul 31, 2015.
  1. Lynx2017
    Lynx2017 Notebook Evangelist
    @Phoenix
    on your old thread you deleted for custom Win 10 ISO
    you had instructions listed for RegEdit, to delete a few things... what were they again? what was the Find Next word you used?
  2. GreatD
    GreatD Notebook Consultant
    Good day Phoenix. I apologize if this has been asked and fixed before. Hope you well. I have a problem and sometime my laptop reboots on it's own so I checked Event Viewer and I saw this log and it came up a few times.
    WHEA 17- a corrected error has occurred, PCI Express root port
    Vendor ID Device ID: 0x8086:0xA115
    Bus:0x0
    device:0x1 function: 0x5
    Class code: 0x30400
    What does it mean exactly? Do I need to be concerned?
    Thanks so much
  3. Lynx2017
    Vasudev and Tinderbox (UK) like this.
  4. Vaeron
    Vaeron Notebook Evangelist
    Vasudev likes this.
  5. Spartan@HIDevolution
    Vaeron, Vasudev and Papusan like this.
  6. Mr. Fox
    Not sure if this is already posted or not. Didn't see it on forum search. The Redmond Retards are still up to their no-good tricks and endless stupidity in their way of thinking. Appears you need an extra service running (more bloat) to achieve "normal" functionality in v1803. Here's a tweak to help correct their stupidity.
    https://winaero.com/blog/network-computers-not-visible-windows-10-version-1803/
    According to Microsoft, Windows HomeGroup was a terrific feature in the pre-cloud and pre-mobile era, but now it is outdated.
    By default, computers in your local network should be visible when you browse for a network device with File Explorer. With recent changes in Windows 10 version 1803 some computers are only accessible via their names or IP addresses. (This is an example of their abject stupidity. Side note: HomeGroup was never necessary to see and access other systems on your home network, but apparently they do not understand their own products.) To fix this annoying issue, you can apply a simple workaround.
    Fix Network Computers are Not Visible in Windows 10 Version 1803
    1. Press Win + R to open the Run dialog.
    2. Type services.msc in the Run box and hit the Enter key.[​IMG]
    3. In the Services window, scroll down to the Function Discovery Resource Publication service.
    4. Double-click it to open its properties and set its startup type to Automatic.[​IMG]
    5. Now, start the service.
    Vistar Shook, Vasudev, Vaeron and 2 others like this.
  7. Spartan@HIDevolution
    Added to the index. just more crap for us to fix in this broken POS OS. [​IMG]
  8. Papusan
    Rename Power Plan in Windows 10
    A power plan in Windows is a set of hardware and system options that defines how your device uses and preserves power. There are three built-in power plans in the OS. Your PC can have additional power plans defined by its vendor. Also, you can create a custom power plan that will include your personal preferences. Today, we will see how to rename a power plan in Windows 10.
    Vasudev likes this.
  9. Vasudev
    @Phoenix Tab preloading reg trick didn't work on Home editions.
    I had to use gpedit.msc to disable tab preload under Computer and user configuration.
  10. Spartan@HIDevolution
    How to disable the automatic hiding of scroll bars setting in Windows 10:
    Microsoft has introduced a new feature (or rather, nuisance) in Windows 10 recently that automatically hides scroll bars until you hover over their location. This can be confusing because sometimes you might not realize there is even a scroll bar so to disable this annoying setting:
    1) PC Settings > Ease of Access > Display
    2) Turn off "Automatically hide scroll bars in Windows"
    steberg, Vasudev and Papusan like this.
