Discussion in 'Windows OS and Software' started by Spartan@HIDevolution, Jul 31, 2015.
  1. Vasudev
    Ok good. I never enabled spectre protection on w10.
    Papusan likes this.
  2. Lynx2017
    Lynx2017 Notebook Evangelist
    thanks mate I will give this a shot now. Realtime priority is where i elevate the process tree to realtime right, under task manager and process? :D
    edit, nm just read following post, so it won't matter.
    Vasudev likes this.
  3. Spartan@HIDevolution
    How to prevent Microsoft Edge from running on startup in the background:
    One of the most annoying new quirks of Windows 10 Redstone 4 is the fact that Microsoft Edge is loaded in the background every time you start your computer.
    To stop this behaviour:
    1) Press the Windows + R key to launch the run dialogue box
    2) Type gpedit.msc then hit Enter
    3) Navigate to: Local Computer Policy > Computer Configuration > Administrative Templates > Windows Components > Microsoft Edge
    4) Set the "Allow Microsoft Edge to pre-launch at Windows startup, when the system is idle, and each time Microsoft Edge is closed" and "Allow Microsoft Edge to start and load the Start and New Tab page at Windows startup and each time Microsoft Edge is closed" to Disabled
    If you do not have Windows 10 Pro (no access to the Group Policy Editor), then here's an alternative way to disable Microsoft Edge from loading automatically on startup:
    1) Open Notepad
    2) Copy paste the below text including the blank line at the end:
    Code:
    rem Prevent Microsoft Edge from starting and loading the Start and New Tab page at Windows startup and each time Microsoft Edge is closed
    reg add "HKCU\Software\Policies\Microsoft\MicrosoftEdge\TabPreloader" /v "PreventTabPreloading" /t REG_DWORD /d "1" /f
    reg add "HKLM\Software\Policies\Microsoft\MicrosoftEdge\TabPreloader" /v "PreventTabPreloading" /t REG_DWORD /d "1" /f
    3) Save the file with the following name: Disable Microsoft Edge from running on startup.bat (Note the .bat extension, you don't want to save it as a TXT file but as a BAT file)
    4) Right click on the file you just created and choose Run as Admin
    5) Now reboot and after 3 minutes, launch task manager to verify Microsoft Edge is not running
    Or you can download the batch file I made: Disable Microsoft Edge from running on startup.bat
    Primes, Tweety78, Papusan and 2 others like this.
  4. Vasudev
    Do we need to go a step further by disabling background app of MS edge under Settings -> Privacy > Background Apps?
    EDIT: Looks like MS Edge is removed from list of BG apps under Privacy section.
    Mari1225 likes this.
  5. Spartan@HIDevolution
    Vasudev likes this.
  6. Vasudev
    Too many FP's and it even flagged my program designed to kill CPUs. So I turned it off. The detection is aggressive. Flags DDU and other "useful" tools.
  7. Spartan@HIDevolution
    Thanks for confirming, just wanted to make sure that the tweak works.
    Be paranoid...be like Phoenix... [​IMG]
    Vasudev and Papusan like this.
  8. Tweety78
    Tweety78 Notebook Guru
    Thanks for that, I will run it. it seems everytime I run CCleaner it says edge needs to be forced to close and I never even use it.
    Vasudev likes this.
  9. Spartan@HIDevolution
    That will sort it for you
  10. Tweety78
    I applied it and edge process wasnt running but after a while it must somehow gets activated again because I ran ccleaner and again it asked to force close edge. I looked at the processes and there it was listed. go figure.
    Edit: I believe it's tied to Internet Explorer somehow as I use it to connect to my DVR, just a guess.
