Discussion in 'Windows OS and Software' started by Ultra Male, Jul 31, 2015.
  1. Vasudev
    @Lynx2017 Always use ISO instead of ESD, sometimes Dism refuses to use ESD format and sometime the data gets corrupted while reading on the fly eventhough ESD is read-only.o_O
  2. Lynx2017
    Lynx2017 Notebook Evangelist
    I was trying it on Win 8.1. It used to work fine, but oh well. I went back to RS4 and no issues, so I guess I will just stay Win 10, I am tired of fighting Microsoft. I know after this though I am done for a few years. I did the windows defender batch file, shut up ten taskl scheduler, lot of other tweaks. I am not wasting another minute of my life on this crap. All updates are off, no more updates for me, I am done. solid stable system, and I will re-do it all again in 2-3 years. time to game!
    Vasudev and slimmolG like this.
  3. James D
    James D Notebook Prophet
    It's worth to add here about deleting OS update Remediation service in services.msc for those who have re-enabled Update Service.
    Vasudev likes this.
  4. bundyal
    bundyal Newbie
    Who can change this with a script in Windows 10 1803.
    Customize start menu
    User files Show as a menu
    Documents Show as a menu
    Pictures Show as a menu
    Music Show as a menu
  5. Papusan
    How to Restore Default Power Plans in Windows 10
    A power plan in Windows is a set of hardware and system options that defines how your device uses and preserves power. There are three built-in power plans in the OS. Your PC can have additional power plans defined by its vendor. Also, you can create a custom power plan or even add in Micro$h4ft's Ulitimate Power Plan SCAM.
    The classic Control Panel is losing its features and probably will be replaced by the Settings app. The Settings app has already got many settings which were exclusively available in the Control Panel. For example, the battery notification area icon in the Windows 10 system tray was also
    replaced with a new Modern UI. However, the Settings app doesn't include the ability to delete a power plan as of this writing. You still need to use the classic Control Panel.
    Ashtrix and Vasudev like this.
  6. Lynx2017
    This doesn't seem to be working in latest Windows update. I do it, reboot, and I use one click firewall from win aero as well, and when i right click block something in firewall, then i check allowed/blocked page of windows firewall, it doesn't show any of the add rules.cmd or any of the ones i right click block on. thoughts?
  7. Ultra Male
    Ultra Male Notebook Nobel Laureate
    Some say...a picture is worth a thousand words...
    Vaeron, Vasudev, asm1 and 2 others like this.
  8. Lynx2017
    I was looking in the wrong, place, found it and confirmed everything is working fine, thanks.
    Vasudev likes this.
  9. Lynx2017
    Did you gain any performance benefit, benchmark scores, or FPS in games increase when you disabled these?
    edit: just disabled it and ran before and after benches. I actually lost points in Cinebench with meltdown and spectre disabled. heh. i'll pass and leave both on
    Vasudev likes this.
  10. Vasudev
    When running CB r15 use Realtime priority and see the before/after results.
    Lynx2017 likes this.
