Discussion in 'Windows OS and Software' started by Ultra Male, Jul 31, 2015.
  1. Ultra Male
    Ultra Male Super Tweaker
    That's why I only use NOD32 Antivirus not the Internet Security. The Antivirus has an HTTP Scanner to block malicious downloads
    A good alternative method would be, depending on your router model, you can add those addresses individually to your router's firewall that way your entire household is protected
    see: [​IMG]
    In the past, owners of higher licenses can install a lower product using the same license key.
    Example, you have an ESET Internet Security License, you can install ESET NOD32 using your same license and it would work.
    Don't know if this has changed but worth mentioning.
    Mari1225 and Papusan like this.
  2. Ultra Male
    Sorry I should have thrown this in:
    Papusan and Lynx2017 like this.
  3. Vasudev
    Try windows firewall control from binisoft or Sphynxsoft.
    Mari1225 likes this.
  4. Lynx2017
    Lynx2017 Notebook Evangelist
    lol nah just slightly dyslexic, nothing you can do will help, except let me visit you in Abu Dhabi so I can flirt with the beach ladies :D
  5. Papusan
    I don't think you will find them here afterwards:vbbiggrin:
  6. Vasudev
    That's the last day phoenix will be sleeping in his villa since his wife will kick him and all his devices, routers, cats into his car.
    6730b and Lynx2017 like this.
  7. Mari1225
    Mari1225 Notebook Consultant
    Ok great! Yes this worked to go back down to antivirus only. Also I was able to keep Defender blocked and access firewall rules just fine, which all the added rules you posted were already added from before still (; Super right! Then I tried out Binisoft to control Windows firewall better and So far its worked awesome with some testing and learning.
    :vbthumbsup::biglaugh::vbbiggrin:
    Vasudev and Ultra Male like this.
  8. Papusan
    How to Enable or Disable Timeline in Windows 10 @Phoenix:rolleyes:
    In Windows 10 Version 1803, there are more useless features like time line that need to be disabled.
    Microsoft wants to keep track of your every mouse move and report it back to the cloud. They are truly disgusting. Endless updates so they can slide in more spyware to each new version of Windows. Disgusting!!
    Vasudev, 6730b and Ultra Male like this.
  9. Vasudev
    Timeline never works for me don't know why? Explorer crashes and restarts itself.
  10. Shubu
    Shubu Notebook Enthusiast
    Appreciate for that post, and Your really hard work. This 'manual' is a life saver. Thanks !
    Papusan, Vasudev and Ultra Male like this.
