Discussion in 'Windows OS and Software' started by Ultra Male, Jul 31, 2015.
  1. Ultra Male
    Ultra Male Super Tweaker
    Dism++ - Windows 10 Cleaning and Tweaking Tool
    Download Dism++
    DISM++ is a free Windows OS Image Customizer and Size Reducer tool
    DISM is a built-in Windows tool that helps you repair System Image and more. You can use the DISM tool to check the health of your Windows image, manage the OS image and restore it in case anything is wrong with it. However, putting aside the vast functionality that this command line tool offers, it is a bit difficult to use if you do not know the commands. So today, we’re going to take a look at DISM++ which is a free portable application for Windows that comes bundled with a vast list of options to help optimize and manage your Windows operating system.
    DISM++ for Windows
    Fully compatible with Windows 10/8.1/8/7, DISM++ can be considered as an extended version of DISM utility, with features like System Repair, Startup Management, Driver & Feature Management and much more. You can just roll in on DISM++ and perform all these operations quite conveniently and easily using its GUI.
    Apart from the general functionalities, you can also enjoy extra features like Make an ISO file using ESDs, Cross-conversion of WIM (Windows Imaging Format) file to ESD/SWM files and even Manage user accounts on your PC.
    All the main features are clubbed into three groups (Utilities, Control Panel, Deployment Features) that you can access from the left side pane of application GUI. Let’s take a brief look at all these features.
    Utilities for effective management
    DISM++ comes holstered with several utilities to manage and optimize Windows effectively. You can scan through the System files and check the image health on the go. You can also manage the startup applications and services by enabling/disabling them per your desired PC performance. Additionally, you can manage the AppX bundles installed on your PC as well which are divided into user apps and provisioned apps.
    Disk Clean
    Toolkit
    A toolkit is also available with a number of options like System Backup & Restore, Startup Repair, Activation Backup, ESD/ISO/WIM file conversion, God Mode etc., which adds up to the usefulness of the application.
    DISM++ Control Panel
    Under this feature group, you can find System Optimizer, using which you can tweak various system-wide settings for the System administrator and other users on your PC. Apart from this, you can manage the drivers and features installed on your PC, export or delete the existing ones and add the new drivers and enable/disable the features available for your version of Windows.
    It also allows you to uninstall the additional features and capabilities present on your PC such as language packs, supplemental fonts, graphics tools etc. Update management lists all the installed updates on your PC and enables you to scan and remove the selected ones.
    Deployment features
    This group doesn’t contain much apart from mostly enabling you to import or export the Windows image default application associations.
    DISM++ seems to be a pretty promising and neat program to effectively manage your Windows PC. It brings a lot of features to the table! You can find all the optimization and management features under one hood which makes it possible even for the newbies to optimize the system performance. You can download it from Softpedia.
    Do let us know what are your thoughts on the same, in the comments section below.
    Source: The Windows Club
    steberg, Vasudev, Vaeron and 2 others like this.
  2. Papusan
    Why not put up the info and download link from your preferred download page MajorGeek ?:eek:
    Vasudev likes this.
  3. Ultra Male
    You wanna get me banned bro? :rolleyes:
    I've been told in the past by our awesome but now missing Ethrem that it is always best to link to the source of the download rather than a 3rd party site unless the source has a confusing or hard to navigate webpage. :rolleyes:
    @toughasnails what say you chief?
    Vasudev and Papusan like this.
  4. Papusan
    Shouldn’t be more different than what was posted in the Software Updates thread.
    Vasudev and Ultra Male like this.
  5. Ultra Male
    Mr. Tim is gonna love you for your loyalty to Major Geeks :eek:o_O
    Link edited
  6. Papusan
    I don’t look at brand(in this case... website). We see all too much websites put in malware in download packages. Not all places you should download software, bruh.
    Vasudev likes this.
  7. Ultra Male
    Yes offcourse. I've been using Major Geeks since more than 10 years and I have not any malware :rolleyes:
  8. Papusan
    steberg, Vasudev and Ultra Male like this.
  9. Vaeron
    Vaeron Notebook Evangelist
    @Phoenix Thanks for this. I quickly ran it, and I saw some interesting things with it. Any suggestions on what Appxs stuff can be easily removed, or do we even bother because we've already tweaked those (Xbox stuff, Camera, etc.) before?
    Vasudev likes this.
  10. Vasudev
    Was using CNET in ancient time when I had dial-up connection.
    Phoenix: It was about time you posted Dism++. Great Utility I have used. Aside from spelling mistakes and other minor stuff the tool is greatest thing I have used. Just make sure Win update difference engine is set to full in Settings for enhanced WU detection and thorough cleanup.
    You have to be careful. Keep Camera,XBox,Zune music,photos app/w7 photo viewer,file explorer, Bio enrollment, Xaml Advertising, .Net native frameworks and few more.
    Vaeron likes this.
