Discussion in 'Windows OS and Software' started by Ultra Male, Jul 31, 2015.
  1. Ultra Male
    Ultra Male Super Tweaker
    How to enable or disable the Meltdown and Spectre Patches
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]
    "FeatureSettingsOverride"=dword:00000000
    "FeatureSettingsOverrideMask"=dword:00000003
    Code:
    "FeatureSettingsOverride"=dword:00000003
    Copy the lines within the spoiler in a blank text document, then save it as Enable or Disable Spectre-Meltdown fix.reg then right click on it to merge it with your registry. You must reboot for the changes to take effect or you could simply copy/paste the commands in an elevated command prompt.
    What do the switches mean:
    3 = disable both
    2 = disable meltdown (VA Shadow)
    1 = disable spectre (BTI)
    0 = enable both
    FeatureSettingsOverrideMask is always 3
    Download InSpectre to check the status of the Intel Patch
  2. slimmolG
    slimmolG Notebook Consultant
    Thanks Bro, that's very useful info!
  3. Ultra Male
    yeah I'd rather risk a 1% chance of being hacked then have Microsoft and Intel rob my taptop's performance :rolleyes:
    @Mr. Fox @Falkentyne @Papusan @Prema
  4. Ultra Male
    @Mr. Fox
    Hmm, I ran the batch file as admin but it didn't add the values in the registry. When I manually copy/pasted them in command prompt though it did
    This is the code I put in the .BAT file and I ran it as admin (my UAC is disabled though if that matters)
    Code:
    reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v "FeatureSettingsOverride" /t REG_DWORD /d 3 /f
    reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v "FeatureSettingsOverrideMask" /t REG_DWORD /d 3 /f
    What gives?
  5. Ultra Male
    Lemme try enabling UAC then see if the batch file works.
    Edit: Nope, enabling UAC and running the BAT file doesn't work
    Lemme try just saving the commands as a reg file now.
    Standby please
    Donald@HIDevolution and Vasudev like this.
  6. Ultra Male
    Instructions have been changed to create a Reg File instead since the batch file wasn't working properly [​IMG]
  7. slimmolG
    Most definitely! I'm looking to increase my P650HS-G performance-- at least to the most it can be-- not help Intel de-mod it. And when a GPU compute run can take 2-4 days to finish, I'll take even an extra 5% performance boost anywhere I can get it.
    Thanks again for the recheck on the .reg
  8. Ultra Male
    Here is what the InSpectre app shows after I've disabled the Meltdown and Spectre Patches:
  9. saturnotaku
    What software do you use for your RAM disk?
    Vasudev and Donald@HIDevolution like this.
  10. Ultra Male
    PrimoRam Disk v6 Beta which is compatible with Windows 10 Fall Creators Update
    I also use PrimoCache:
