Discussion in 'Windows OS and Software' started by Ultra Male, Jul 31, 2015.
  1. Ultra Male
    Ultra Male Super Tweaker
    that's useless bro. It just tells you how to restore a plan to its default settings. the problem with the Fall Creators Update is it has NO Power Saver and High Performance Plan, those need to be created manually. So I'm not seeing what benefit is that link above, with all due respect :rolleyes:
    Maleko48, Vasudev and Papusan like this.
  2. Papusan
    Is there a guide how to remove balanced Power plan completely from the planet? Aka a cleaner power plan.
    Beemo likes this.
  3. Ultra Male
    you need to edit the source code of the Windows Kernel [​IMG]
    Maleko48 and Vasudev like this.
  4. Vasudev
    Maybe power subsytem options are commented out so naturally there's a chance of restoring it.
  5. macmyc
    macmyc Notebook Consultant
    Guys there is an easier way to restore it. Simply make a new power plan and it will ask you to choose between Balanced, High Perfomance and Battery Saver, you'll just have to rename it. That's how i got them back on my laptop.
    edit: aw, i just realized Phoenix mentioned it already. woopsie
    Vasudev likes this.
  6. Chowda289
    Chowda289 Notebook Geek
    @Phoenix If I added O&O Shutup10, do you still recommend doing the other "disable telemetry" and suggestions under the index? Examples: "Stop Windows 10 spying on you using just Windows Firewall", "Mr. Fox's Tweaks", "Winaero Tweaker"
    Is there no way to change that Windows does automatic updates? :mad:
    What are the pros and cons of disabling Windows automatic driver updates?
    Vasudev likes this.
  7. Vasudev
    There are only Pros and no cons.
    - system instability
    -More headaches
    etc..
    Use Policy Plus from github to disable that policy Or disable BITS and WU service and only enable them whenever Tuesday patch is out for auto updates. I use WHDownloader for offline updates only. So, I use WU and BITS to update UWP apps.
    Chowda289 likes this.
  8. larry bear
    larry bear Newbie
    I just found this thread on tweaking win 10. Thxs @Phoenix for this. My new laptop will arrive next week and am eager to configure it properly with this guide.
  9. Papusan
  10. Toshi001
    Toshi001 Notebook Enthusiast
    Hi @Phoenix
    Thanks for your help last time. I looked at tour win 10 tweaks and decided to try the above with my new laptop, following all your recommendation above too.
    Once I restarted my laptop, I saw the laptop logo, it then turns to an all black screen and I can only see the mouse cursor (can move it around) but its stuck in this black screen.
    Have tried to turn it off (holding power button, no way to turn off properly) and when I turn it on again, still the same problem.
    Please help me. Kinda regret even trying this.
    Anyway to fix it? Thanks.
    Vasudev likes this.
