Discussion in 'Windows OS and Software' started by Phoenix, Jul 31, 2015.
  1. Papusan
    Papusan JOKEBOOKS = That sucks!! STAHP! Dont buy FILTH...
  2. James D
    James D Notebook Prophet
    This works on Windows 7 too (just checked). Now if ms morons had provided the GUI way for blacklisting those wi-fi networks right from the wi-fi window then it would have been 'nice new tool brought by win10 update'. But in that case they wouldn't have been morons... for 3rd year in a row. That is how you bring new good product, by making it better instead of doing 10 steps back and changing everything for the sake of change.
    P.S. Still thanks for this hack. Might use it some day and definitely save commands for that.
    Papusan and Vasudev like this.
  3. XiCynx
    XiCynx Notebook Guru
    Not sure if anyone has mentioned this and I didn't see it on the list, but WDP looks like an alternate version of O&O Shutup10 that is slightly better categorized and gives slightly better explanations for what you are disabling.
    https://www.ghacks.net/2017/06/19/windows-10-privacy-wpd/
    Vasudev likes this.
  4. Mr. Fox
    Papusan, Vasudev and steberg like this.
  5. Phoenix
    Phoenix Super Tweaker
    ESET's NOD32 Antivirus' HTTP Scanner blocked the URL for WPD.
    ESET has been known to have 0 false positives or very little for many years. Proof: False Positives Latest Test
    Thus, not coming near this with a 10 foot pole.
    I will only stick to O&O ShutUp10 because ironically, they are a Micro$h4ft Partner and their software never breaks anything nor does anything suspicious :d:eek::rolleyes:
    Papusan, deekeasy and Vasudev like this.
  6. Phoenix
    How to disable the lock screen
    Copy/paste the following text in a text notepad then save the file with a .reg extension then double click on it to merge it with your registry
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Personalization]
    "NoLockScreen"=dword:00000001
    Mr. Fox likes this.
  7. Phoenix
    Winaero Tweaker v0.9
    Fixes & Improvements
    • Fixed: The "Command Prompt as Administrator" and "PowerShell as Administrator" menus were not working in Windows 7.
    • Fixed: The "Wallpaper location" context menu wasn't working in Windows 7.
    • Fixed: The "Elevated Shortcut" feature wasn't working in Windows 7.
    • Fixed: The Control Panel context menu wasn't working in Windows 8/8.1.
    • Fixed: The "Disable wide context menus" feature was reporting invalid status. Also, I've added a "Restart Explorer" requirement.
    • Fixed: The default file name template "Winaero Tweaker_8/17/2017.ini" in Import/Export was changed to "Winaero Tweaker_8.17.2017.ini" for all languages and supported operating systems.
    • Fixed: A "null reference" error message could appear after you remove "OneDrive" from the navigation pane.
    • Updated: The System Font tweak now comes with a new design.[​IMG]
    The following tweaks do not work in Windows 10 version 1703 and above:
    • Updated: The "Enable new share pane" tweak is now removed for Windows 10 version 1703 and above.
    • Updated: The "Enable the new OneDrive flyout" tweak is now removed for Windows 10 version 1703 and above.
    • Updated: The "Enable new share page" tweak is now removed for Windows 10 version 1703 and above.
    • Updated: The tweak "Disable Auto Reboot after Updates" is now removed for Windows 10 version 1709.
    Papusan, Mr. Fox and Vasudev like this.
  8. Mr. Fox
    This is one of my favorite tweaking tools.
    I wish I could say I liked Windows 10 even half as much. It sucks how much functionality Micro$loth keeps removing with every new flavor of Windows 10 feces.
  9. Phoenix
    did you see the amount of tweaks available? that's how bad Windows 10 is and needs to be tweaked and stripped down. I love the old Classic Alt+Tab which is much simpler with no preview.
    Papusan, Vasudev and Mr. Fox like this.
  10. Mr. Fox
    Yeah, absolutely agree with you. I can't think of any word to describe it other than "pathetic" how crappy Windows 10 has become.
    Papusan and Phoenix like this.
