Discussion in 'Windows OS and Software' started by Phoenix, Jul 31, 2015.
  1. tutelo
    tutelo Notebook Enthusiast
    Nice to know, however that doesn't help me right now. I ran win update manually to check for updates and it started downloading the Fall Cremators Update. I was able to pause it, but that "thing" will still end up on my computer in 30 days and I don't want it yet. If I cant stop that travesty from installing, do I have to redo all the tweaks listed here again? Btw I dont have any disk images saved.
    Vasudev likes this.
  2. Phoenix
    Phoenix Super Tweaker
    Macrium Reflect Installation/Usage Guide
  3. tutelo
    Thanks @Phoenix. Besides backing, any tips for what to do before/after creator's update installs? I kinda shot myself in the foot with that
  4. Phoenix
    1) Crate an image using Macrium Reflect using the above guide just in case you wanna go back
    2) Undo all the tweaks we changed in O&O ShutUp 10 then reboot. There is an option from the top left menu to revert back all settings to stock
    3) Install Fall Creators Update
    4) Run O&O Shutup 10, then load the following config file to have it configured with my recommended way: http://www.mediafire.com/file/slnb45hpv1jjwpw/ooshutup10.cfg
    5) Reboot when prompted
    6) Run O&O ShutUp10 again and click REVERT to revert back Telemetry 3 of 3 which Windows probably re-enabled then reboot again
    Done
    tutelo likes this.
  5. tutelo
    Sweet. Thanks again for the help! :notworthy:
  6. Phoenix
    Papusan likes this.
  7. Gotas
    Gotas Newbie
    Hi, @Phoenix. How do I install the Windows 7 calculator in Windows 10 Fall Creators Update? and can it be put in Spanish?
  8. Phoenix
    It's not out yet, once it is I will post it.
    and no Spanish Amigo. English only
    Vasudev likes this.
  9. Phoenix
  10. Vasudev
    Vasudev Notebook Prophet
    Already enabled for better audio experience on mediocre speakers and headphones.
    On Nahimic or Sound Blaster based audio solutions Windows Sonic produces low volume when 7.1 virtual surround is enabled. YOU must tweak the Bass Boost frequency, Headphone Virtualisation (Jazz or Studio) and set audio sampling rate to 24bit at 96kHz or 192kHz
