Discussion in 'Windows OS and Software' started by Phoenix, Jul 31, 2015.
  1. j95
    j95 Notebook Deity
    10AppsManager is a freeware that will allow you to easily uninstall and reinstall the default, built-in, preinstalled Windows Store apps in Windows 10. While you can always manually install, uninstall or reinstall the Store apps, the process is not so easy for the preinstalled apps. It is easy to uninstall or reinstall 3rd-party apps, but not the default preinstalled apps. What this tool from our TWC stables does, is automate the process and let you carry out the operations in a click.
    http://www.thewindowsclub.com/10appsmanager-windows-10
    Edit: Only untouched ISO's for the time being...unfortunately [​IMG]
    @Mr. Fox
    TBoneSan, jaug1337, Papusan and 2 others like this.
  2. Vasudev
    Vasudev Notebook Prophet
    Try Dism++ and wipe UWP completely w/o leaving behind any traces. I freed 2 GB after uninstalling 3 apps.
  3. Phoenix
    Phoenix Super Tweaker
  4. 7leagueboot
    7leagueboot Notebook Consultant
    I cannot see any ZIP file to download however, I use a standalone 3rd party firewall. Would it be possible to post the rules to be added please?
  5. Phoenix
    In that link, scroll down below where the rules are mentioned, then you will see the download link
    Papusan and Vasudev like this.
  6. Papusan
    Papusan JOKEBOOKS = That sucks!! STAHP! Dont buy FILTH...
  7. Phoenix
  8. Papusan
    Maybe M$ don't cripple performance with the new Alpha OS for own games:D Better with a few games who run normal on the Alpha OS build:p
    Vasudev likes this.
  9. Papusan
    Disable Apps Auto Reopening in Windows 10
    "Starting with Windows 10 Fall Creators Update, the operating system is able to automatically reopen apps which were running before shutdown or restart. This behavior is totally unexpected for most Windows users who upgraded to the recent release of the OS. Here is what you can do to change the situation and stop Windows 10 from restoring previously open apps after a reboot."
    "From what I read on Neowin and Reddit, I see many people are frustrated by this change. Actually, it's not clear why we need this feature if we already have the Startup folder." Brilliant move from Morons HQ!!:no:
    Ashtrix, Vasudev and steberg like this.
  10. Vasudev
    So if you had UWP games running then it will also startup automatically when I'm presenting a Powerpoint based slideshow.Great idea, I think.
    So, I will have more shortcuts on desktop to restart or shutdown PCs. I'm freezing the update of W10 Creators update until the users want the OS how it was before.
