Discussion in 'Windows OS and Software' started by Phoenix, Jul 31, 2015.
  1. 7leagueboot
    7leagueboot Notebook Consultant
    Before Win 10, it used to be that you could right click on an icon and select Properties. That option has been removed so is there any way to put Properties back in the context menu please?
    I would like to correct this nonsense that appeared on my taskbar this morning:
  2. Vasudev
    Vasudev Notebook Prophet
    Is outlook mail open?
  3. 7leagueboot
    Yes and no. I have had it open a few times and closed it while using compatibility troubleshooter. The icon remains only ⅛ of its normal size.
    I also tried right clicking on the executable's icon but the Properties dialogue offers no option for changing the icon.
    Edit:
    I just created a shortcut in the Program Data folder and then changed the shortcut's icon. That doesn't work either. :(
    2nd Edit:
    Restarting the PC fixed it. I would still like to have the Properties option in the context menu though. I'm sure I won't be alone with that.
  4. Phoenix
    Phoenix Super Tweaker
    Papusan and James D like this.
  5. vorob
    vorob Notebook Deity
    So, my app is frozen and I click on it RMB in the taskbar and select "Close Window", nothing happens. Hate this! Then I have to open task manager, search for the process, then RMB and "end process tree". Why? Why doesn't it closes a window in the first place? How can I correct this behavior? Thx!
  6. Phoenix
    To get better answers, post in the right section!
    hmscott likes this.
  7. Phoenix
    How to turn off smart multi-homed name resolution in Windows
    Tweak removed due making your internet extremely slow
  8. Mr. Fox
    Well, hallelujah... AeroGlass is finally available for Windows OS X Creators Abortion, so we don't have to tolerate the pastel vomit UI any more!!!
    http://www.msfn.org/board/topic/176668-when-will-there-be-a-version-for-windows-10-1703?/?page=7&tab=comments#comment-1143167
    Download version 1.5.4 for Creators Abortion. Your existing donation key will work if you had a previous version of M$ OS X installed on the same drive.
    http://www.glass8.eu/
    All of my previous settings still work same as before as well.
    Scerate, Vasudev, TBoneSan and 3 others like this.
  9. 0lok
    0lok Notebook Evangelist
    Hi @Mr. Fox I have tried this command and it will say operation successful but when I reboot and spam f8 it doesn't work. I dont know why. Also I dont have fast start up as I have disabled it and disabled hibernation. Did I do something wrong? My current winver is Version 1703 OS build 15063.540. Help please. Thank you.
    Edited: I have a Alienware 17 r3 i7 6700hq 970m.
    Mr. Fox likes this.
  10. Mr. Fox
    It is still there, but not very obvious. Their mission to to make things more difficult and call that easier due to loss of functionality. Micro$loth have removed the ability to manipulate the properties of the "special" shortcuts created during Office setup. You have to create your own shortcut to edit the properties. This applies to all Office programs.
    To tweak the properties of the shortcuts that they haven't screwed up, you do it as shown below.
    Vasudev and Papusan like this.
