Discussion in 'Windows OS and Software' started by Phoenix, Jul 31, 2015.
  1. Phoenix
    Phoenix Colonel
    Papusan and the crew: [​IMG]
    ajc9988, steberg, hmscott and 3 others like this.
  2. Papusan
    Papusan BGABOOKS = That sucks!! STAHP! Dont buy FILTH...
    Is there any point install the CS Update? Install and disable with Autoruns.exe or skip it?
    hmscott and Phoenix like this.
  3. Phoenix
    Phoenix Colonel
    nope, we are the updates team, we don't need no app checking for updates :D
    I uncheck all options except Classic Start Menu
  4. Papusan
    Of course as always. I have no needs for software looking for updates. Can of course disable with Autoruns.exe but better without (Very importent if you have BGA:rolleyes:) Every clock cycle counts as you know:D
    Vasudev and hmscott like this.
  5. Phoenix
    Phoenix Colonel
    Vasudev, hmscott and Papusan like this.
  6. Phoenix
    Phoenix Colonel
    How to disable the Windows Defender Security Health Service:
    While you can easily disable Windows Defender and all its startup entries/tasks in task scheduler, there is one service that is protected if you check in services.msc and won't allow you to change its status to disabled.
    Here is how you can disable it:
    1) Download NSudo 4.0
    2) Extract the content of the ZIP file to a location of your choice.
    3) Go to the following folder: NSudo v4.0\x64
    4) Right click on NSudo.exe and choose Run as Administrator
    5) Check the box which says Enable All Privileges
    6) Click the Browse Button and navigate to C:\Windows\System32
    7) type cmd.exe in the file name box at the bottom then click on the Open button
    8) your NSudo window should now look like this:
    9) Click the Run Button, the command prompt window should now launch
    10) Copy/paste the following command in the Command Prompt Window then hit Enter to run it, this will stop the Windows Defender Security Center Service: sc stop SecurityHealthService
    11) Copy/paste the following command in the Command Prompt Window then hit Enter to run it, this will disable the Windows Defender Security Center Service: sc config SecurityHealthService start= disabled
    12) Done
    Ashtrix, hmscott, Mr. Fox and 3 others like this.
  7. markwilliams
    markwilliams Newbie
    As noted in my full review of Windows 10 Anniversary Update, many of the improvements in the latest version of Windows 10 simply don’t apply to typical Windows 7 or 8.1 users.
    hmscott likes this.
  8. ajc9988
    hmscott, Mr. Fox and Phoenix like this.
  9. Papusan
    ajc9988 and hmscott like this.
  10. Ike11000
    Ike11000 Notebook Enthusiast
    I seriously cannot thank you enough for the awareness you're spreading among the community and the consolidation of solutions. I was planning on just ordering my laptop and playing with it with little to no tweaks, but you have shown me the light. Once again, props to @Phoenix, @Papusan and @Mr. Fox for the crazy amount of help.
