Discussion in 'Windows OS and Software' started by Spartan@HIDevolution, Jul 31, 2015.
  1. Spartan@HIDevolution
    Right I totally forgot about that. I'll try it
  2. Vasudev
    Yeah. https://github.com/abbodi1406/BatUtil
    Use Git and use Git clone and git pull to keep the batutils updated.
    Go to YAOCTRI folder and your appropriate version CTRIR -> Retail versions of MSO 2016-365 or CTRI -> Volume License or Business version given by your Company/Organization.
    Don't forget to use cmd prompt as admin and provide Root folder of Office cab files for example: If you downloaded the offline cab files to C:\office_install\<your office version>\ ...
    Give Office path as C:\office_install so that it detects proper installation setup files.
    Fire Tiger and Papusan like this.
  3. Spartan@HIDevolution
    @Mr. Fox
    YAOCTRI_v9.0 worked to do the custom install
    The installation finished in like 40 seconds!
  4. Mr. Fox
    Nice! Thanks for sharing. If I ever decide to install Micro$lop Office again I will give it a go. I am hoping I can learn to live without it, and things are certainly shaping up that way now that I have found alternatives I can live with.
  5. Vasudev
    I use the same apps like you do. YAOCTRI is much faster than MSFT OfficeSetup where I had to wait 5 hrs and waste 4GB of data and setup was still stuck at 1%.
    Grabbed OfficeRTool to download stable LTSB office version and YAOCTRI and within 1 hr everything was setup.
    Papusan and Spartan@HIDevolution like this.
  6. Spartan@HIDevolution
  7. Spartan@HIDevolution
    Add Run in Sandbox Context Menu in Windows 10
    WARNING: You cannot reverse this tweak after doing it. I personally found the context menu entry annoying as I was accidentally clicking it when right clicking and trying to run a program as Administrator
    After Enabling Sandbox in Programs & Features / Turn Windows Features On or Off
    Reboot
    Make sure the the ZIP file you downloaded is not blocked then extract it:
    It defaults to French language. Edit the .\Sources\Run_in_Sandbox\Sandbox_Config.xml file to use the language code you want, e.g. set en-us for English.
    In that folder, click on File > Open Windows PowerShell > Open Windows PowerShell as Administrator in File Explorer.
    Now, right-click on some executable file. You'll see the Run in Sandbox entry
    Vasudev likes this.
  8. MyHandsAreBurning
    MyHandsAreBurning Notebook Enthusiast
    Papusan and Mr. Fox like this.
  9. Papusan
    The better idea is to disable it completely.... http://forum.notebookreview.com/thr...nd-announcements.826887/page-64#post-11037741
    Mr. Fox and Vasudev like this.
  10. Mr. Fox
    Another happy Windows 10 user... loving that Kool-Aid
    Another+reminder+that+i+cant+hack+it+in+the+army+_85eda6478e5e450fa39680bebb344cc6.jpg
    cfe, Vasudev and Papusan like this.
