Discussion in 'Windows OS and Software' started by Spartan, Jul 31, 2015.
  1. Papusan
    You was just lucky. Born under a lucky star?:D
    One of many different cases... Some Win10 PCs are apparently being upgraded to version 2004 without consent
    Vasudev and Spartan like this.
  2. Vasudev
    Yeah. I'm not that lucky!
    1909 was a disaster on my AW BGA, no audio and sometimes doesn't boot after a Clean install but in-place upgrade to 1909 from 1809 boots just fine. I'm stuck at infamous black screen before POST or just stuck at AW UEFI screen.
    Papusan likes this.
  3. James D
    James D Notebook Prophet
    There was trick to download gpedit for Win10 home edition called add_gpedit_msc_by_jwils. Did it stop working?
  4. Vasudev
    I use that till v1803 and gpedit tweaks stopped working for MS Edge but that's the reason I switched to Chromium Edge which can be tamed to an extent.
  5. Primes
    Primes Notebook Deity
    this link is broke in post (1) of this thread.
    Code:
    1) Download the Photo Viewer Restore Reg Entry then double click on it to merge it with your registry
    Its the link for download right above Spartans signature in post (1).
    Spartan likes this.
  6. Spartan
    Spartan Super Tweaker
    Fixed, thanks for reporting.
    Primes and Vasudev like this.
  7. jasonmbrown
    jasonmbrown Newbie
    Spartan could we get a bulk download of the tweaks? (At least the registry edit tweaks)
    Fire Tiger likes this.
  8. Spartan
    H3r3 j00 g0 = Spartan Tweaks [​IMG]
    Before unzipping the ZIP file, right click on it, choose Properties, then check at the bottom, if it says this file came from the internet and might be blocked, click the Unblock button then hit Apply, then Ok. If you don't do this and extract it while it's blocked, then every single file will have a BLOCKED status. To Prevent this automatic blocking of downloaded files in Windows, be sure to check this guide: "Are you sure you want to run this file?" [Yes or No]
