Discussion in 'Windows OS and Software' started by Ultra Male, Jul 31, 2015.
  1. ht_addict
    ht_addict Notebook Evangelist
    When I run WUP and check disable service and Protect Service Settings, I notice in OOShutup10 that Automatic Windows Update disabled 2 of 2 turns red, with an Admin Privilege icon next to it? Any ideas why?
  2. Mr. Fox
    Others (including me) have noticed that this happens. Probably just a software conflict/clash. Likewise, f you use Group Policy Editor or manually tweak some registry keys to change certain settings they do not always show as already being changed using third-party utilities like Winaero Tweaker.
    I doubt that either program is malfunctioning. O&O Shutup10 is probably showing that because WUB has taken control of that setting and it no longer has the ability to implement the same tweak. Because access is denied and it cannot change it to green in its own UI it shows up in the way you have noticed.
    Vasudev likes this.
  3. Ghost 350
    Ghost 350 Notebook Geek
    Hey Mr. Fox I don't know where else to reply. So I gave my laptop to Hidevolution for repair. I was getting the 4 beeps on POST and thought it was a ram issue. They replied back saying its a mobo issue and they will be getting a new one. Is there any way I can keep my OS intact without doing a fresh install? I really don't wanna use Win 10 and have an awesome Win 7 tweaked setup running on it (like it won't allow updates to 10, various registry tweaks, etc.). Thanks for your time.
    Vasudev and Mr. Fox like this.
  4. Mr. Fox
    Hi bro. You should be OK. You should not require an OS reinstall after replacing the mobo with another one just like it.
    Ghost 350 and Vasudev like this.
  5. JoeT44
    JoeT44 Notebook Consultant
    Hi Bro, Glad you are back home safe. I sent you an EM.
  6. Ghost 350
    Thanks!
    Mr. Fox likes this.
  7. Papusan
    How to delete Downloaded Windows Update Files in Windows 10
    If you are running into issues with Updates, you can try to delete downloaded Windows Update files. When an update package is damaged or fails to install, Windows 10 may keep the corrupted file on the drive, so it will further cause issues with updates. Here is how to delete the downloaded Windows Update files that Windows 10 doesn't delete itself.
    Vasudev likes this.
