Discussion in 'Windows OS and Software' started by Spartan, Jul 31, 2015.
  1. Vasudev
    Haha... Compatibility mode can enforce or bypass newer cert checks for few times and then blocked because W7 and upwards enforce ShA2 hash as safe and rest below that are insecure.
    Xatanú likes this.
  2. Xatanú
    Xatanú Notebook Consultant
    Thank you. That must be the cause. There should be an easy way on Windows for disabling this enforcement.
    Vasudev likes this.
  3. Vasudev
    Even Linux, Android etc.. have classified SHA1 cert as unsafe. DoD NIST have classified the same.
    Xatanú likes this.
  4. Papusan
    Spartan, Avé César and Vasudev like this.
  5. Avé César
    Avé César Notebook Consultant
    (Edit : works )
    Edit : I had to add a "user.png" (448x448) or couldn't works on my PC. So i used a online app, to resize the one downloaded, cause Microsoft paint resize, remove the transparency...
    hmscott likes this.
  6. Spartan
    Spartan Notebook Nobel Laureate
    Added to the Index [​IMG]
    Vasudev, Papusan and hmscott like this.
  7. Papusan
  8. Mr. Fox
    diggy, Ashtrix, steberg and 6 others like this.
  9. Papusan
    How to Add Device Idle Policy to Power Options in Windows 10
    In Windows 10 you can add the "Device idle policy" option to the Power Options applet of the classic Control Panel. It determines whether conservation idle timeouts or performance idle timeouts are used for devices that are integrated with Windows kernel power manager device idle detection. It is a hidden option that is not visible by default.
    Ashtrix, 4W4K3, Vasudev and 2 others like this.
  10. Vasudev
    If you're using my custom Win7/10 images those are already integrated. Haha.... I think MSFT should un-hide it.
